2000 Mustang GT Many upgrades
NorrFam
 Share
Plans in works to get new car. Need to move this one or bride will not approve the new one. You know how that goes.
Located in Raleigh area and at NASA-SE events
4.6L 2v
Oil Cooler
C&L throttle body and plenum
AEM cold air intake
Performance Intake manifold
Comp Cams - 102600 - Duration 270/274, Lift .550/.550
BBK Long Tube Headers
BBK X-pipe off road mid-pipe
Magna Flow stainless pipes and mufflers
Fidenza aluminum flywheel
Ford Racing Aluminum Driveshaft w-safety hoop
SPEC stage 3 clutch
T-45 Transmission
Steeda Tri-ax shifter
3.55 Ford reargear
Torsen T2 R in the diff
Fays 2 Watts Link
Tokico HP dampers (Plus one set of same new in the box
Eibach Front and Rear Sway bars 35mm/25mm
Steeda X-2 ball joints
Steeda bump steer ends
BBK LCA’s
Ford “C” springs (lowers the car and has higher rating)
Strut tower brace
UPR camber/caster plates
Wilwood SL6 brakes on front w/14” Wilwood rotors
New stock rotors on the rear
6 - FR500 style 18x9 wheels. 275-35-18 Toyo RR’s mounted but used to varying degrees
Sparco EVO 3 seat – on slider (out of date for racing) VGC
2 sets G-Force 5 point harness (out of date for racing) Like new
There is a low profile but functional (not a decoration) spoiler on the rear deck.
Included is a Cobra R type wing
Some spares and removed interior parts. There is still some weight that can be shed by removing more interior items. Make some money back selling the interior items.
Has 2017 TT Annual tech sticker and new log book.
This car has been totally dependable. Tuned by Fastlane in Benson, NC. Last dyno (2-17) was 281 hp at the wheels. Great for any level of DE or getting your feet wet in TT4.
Cant get picture to post. If genuinely interested will be happy to send a few in email.
 Share
