J.R. Smith Posted March 30, 2017 Share Posted March 30, 2017 1998 BMW M3 NASA ST1/ST2/ST3 (DEPENDING ON RESTRICTOR SIZE) (APPROX. 400 RWHP WITHOUT RESTRICTOR) CAR AND ALMOST EVERY COMPONENT HAS APPROXIMATELY 30 HOURS WEIGHT – 2550 LBS (DRY) ENGINE: LS6 BLOCK WITH STOCK CRANK/RODS WITH ARP ROD AND HEAD BOLTS SPEED PRO COATED PISTONS LS1 PORTED AND POLISHED HEADS BY THOMPSON RACING GM TORQUER CAM (204/218 WITH .550 LIFT @ .050 – 112 LSA SMITH CHROMEMOLY RESTRICTED PUSHRODS STOCK ROCKERS WITH COMP CAMS TRUNION KIT 11:1 COMPRESSION RATIO FAST 92 INTAKE MANIFOLD FAST BIG MOUTH 92MM THROTTLE BODY LS3 INJECTORS LS7 MAF F BODY OIL PAN STOCK GM ECU (TUNED BY FORMER GM ENGINEER) AUTOMETER GAUGES OMP WHEEL MOMO “LESMO” HALO SEAT TILTON DUAL MASTER BRAKE CYLINDERS/BIAS BRAKE PRESSURE GAUGES ALUMINUM FLYWHEEL AND PERFORMANCE CLUTCH FUEL SAFE 22 GAL. FUEL CELL 10 LB. “FIRE SENSE” FIRE SYSTEM COIL OVERS - KONI DOUBLE ADJUST FRONT AND SINGLE ADJUSTABLE REAR SHOCKS SPRINGS – 750LB FRONT/800 LB. REAR GROUND CONTROL CAMBER PLATES AND SWAY BARS VORSHLAG LS CONVERSION KIT POWER STEERING COOLER ENGINE COOLER 3 QT. ACCUSUMP TURN ONE POWER STEERING PUMP COATED HEADERS (INSIDE AND OUT) BORLA STAINLESS RACE MUFFLERS T56 MAGNUM TRANSMISSION TUET-11009 (2.66/1.78/1.30/1.00/0.80/0.63) CUSTOM STEEL DRIVESHAFT 3.73 LSD DIFF – 60% LOCKUP DIFF COOLER GRIFFIN ALUMINUM RADIATOR BRAILLE LIGHTWEIGHT BATTERY ALCON 15 IN FRONT BRAKE CALIPERS PORSCHE BOXSTER S 13 IN. REAR BRAKE CALIPERS SLOTTED/DRILLED ROTORS FISKE 18 X 11 WHEELS PIRELLI DH SLICKS 285 X 645 X 18 CARBON REAR WING $38,500 Quote Link to comment Share on other sites More sharing options...
alwaysinboost Posted March 31, 2017 Share Posted March 31, 2017 any pics? Quote Link to comment Share on other sites More sharing options...
J.R. Smith Posted April 1, 2017 Author Share Posted April 1, 2017 link to pics: http://www.racingjunk.com/NASA-Super-Touring/182865397/FS-1998-BMW-M3-LS-POWERED-.html?categoryId=4183&offset=0&from=category Quote Link to comment Share on other sites More sharing options...
J.R. Smith Posted May 14, 2017 Author Share Posted May 14, 2017 NEW PRICE : $33,698 MORE PICS: http://www.racingjunk.com/NASA-Super-Touring/182865397/FS-1998-BMW-M3-LS-POWERED-.html?searchString=BMW&categoryId1=4&hideNotification=true&page=3&offset=27&from=search Quote Link to comment Share on other sites More sharing options...
J.R. Smith Posted September 24, 2017 Author Share Posted September 24, 2017 SOLD Quote Link to comment Share on other sites More sharing options...
