mattmarks Posted April 17, 2017 Share Posted April 17, 2017 Selling 20' Hurricane Cargo steel enclosed trailer. Purchased new in 2013. Excellent condition. Features - 3500 pound Dexter axles with dual electric brakes (7000lb total trailer gross weight) - Tires - two new replaced in 2015, Other tires original excellent condition more than 75% tread left. 1 mounted spare included - AC/Heat from Factory - Awning from Factory - 2 external 110v receptacles - Accepts 110 or 220 v feeds - cable and adapters included - Built in work/flood lights from Factory - All runnng lights are LED and work - Walk on reinforced roof - Driver's side "escape" door - Etrack set up with shoring beams for tire rack - can hold 300 lbs. Fits 8 245/40 hoosiers plus spare. May fit more, but there the largest I have. Home built working surface and shelves at front of trailer. Trailer weight is approximately 2800 lbs, and tows great loaded with a 944 even behind SUVs. I pull it with a v6 Grand Cherokee with no issues. 944 fits perfectly so am assuming 911s and E36s would do the same. Will deliver within 3 hours of Washington DC. Pictures at: https://marksmatt.wixsite.com/mysite Quote Link to comment Share on other sites More sharing options...
