Canyonfive 0 Posted May 10, 2017 Share Posted May 10, 2017 Hello NASA, Im currently racing a Mazdaspeed Miata prepped for autox. I recently installed a 4 point roll bar that meets your Time Trials Specs and based on the classing information Im in TT4 or TT3 depending on how much boost I run. How does this work with NASA? Do you monitor for boost? Im open to any and all suggestions and guidance. I have done some other HPDE and im a National champion at autox so I was hoping to be able to make the jump to TT without having to attend NASA specific HDPE event. Is there a path to this? Anthony Quote Link to post Share on other sites
int2str 3 Posted May 10, 2017 Share Posted May 10, 2017 The rules have various topics regarding switchable ECU maps, which would apply to you. Basically you need to dyno any configuration you want to run and have the relevant dyno sheets at hand and a way for the inspector to verify which map you're in. Rules are here: https://nasa-assets.s3.amazonaws.com/document/document/481/TT_Rules_2017--v14.1--12-27-16.pdf Search for "ECU" or "map" in the rules to find the relevant sections. Quote Link to post Share on other sites
Canyonfive 0 Posted May 11, 2017 Author Share Posted May 11, 2017 Thank you, when I was trying to find the classes I could fit in using the excel sheet there were certain things that weren't selectable like a larger throttle body. Its says my Base Class is TTE. Here is what I have so far do I add the "none" points or the points? My HP is 225 My weight is 2475 Weight +9 Checked box for forced induction +5 Stand alone ecu (its says none but also +10) Larger Throttle body (it says none but also +2) Fuel system +2 Boost controller +4 Intercooler +7 Post header exhaust piping +3 Changed limited slip +1 Non-remote Double adjustable shocks +3 Springs +2 anti-Roll bars +2 brake calipers +2 Front splitter +3 Rear Spoiler +4 For a total of 46 points so up two classes right there. Plus my tire option of.. 200 tw 245's +2 (plus 1 for 245 width) 48 points > TTE + 2 classes so TTC? 275 Hooisier A7 +22 (plus 10 for width) 78 points > TTE +3 classes and 3 classes is TT4? Quote Link to post Share on other sites
int2str 3 Posted May 11, 2017 Share Posted May 11, 2017 Peak horsepower doesn't count for numbered classes, but if your average power comes out to anything near 225hp, that might be too high for TT4. Let's try: 2475 / 225 = 11:1 -0.2 for weight +0.7 if you can run 245's (can be Hoosier R7's; not A7) If you want to keep aero, you can't take the 0.4 points for OEM Aero in TT4 ============= 11 - 0.2 + 0.7 = 11.5 : 1 = TT3 To make the numbers work for TT4, I think a slight decrease in boost would get you very competitive if you can get your average horsepower to 215, which you might be very, very close to. Then the math works: 2475 / 215 = 11.51 - 0.2 + 0.7 = 12.01 : 1 = TT4 And you won't have to worry about all the other points stuff. Quote Link to post Share on other sites
Canyonfive 0 Posted May 12, 2017 Author Share Posted May 12, 2017 Oh that's much easier. How do I figure average Hp the NASA way? edit: (Hp... kinda wishing I had a diesel) Quote Link to post Share on other sites
getfast 0 Posted May 12, 2017 Share Posted May 12, 2017 Im open to any and all suggestions and guidance. I have done some other HPDE and im a National champion at autox so I was hoping to be able to make the jump to TT without having to attend NASA specific HDPE event. Is there a path to this? The path is to talk to your region's TT director. They will want to see a track driving history with significant advanced level experience (for example, in this region the minimum is 4 weekends in HPDE3) and typically yes you will need to do at least a weekend or more with NASA in a fast HPDE group, plus get a check ride for provisional TT approval. All for safety of course... Quote Link to post Share on other sites
int2str 3 Posted May 12, 2017 Share Posted May 12, 2017 Oh that's much easier. How do I figure average Hp the NASA way? Rules: https://nasa-assets.s3.amazonaws.com/document/document/481/TT_Rules_2017--v14.1--12-27-16.pdf Section 9.2 Depending on the torque curve of your car, you might actually be at 215hp average already. Quote Link to post Share on other sites
Canyonfive 0 Posted May 18, 2017 Author Share Posted May 18, 2017 Again, thank you. So if my Base class is tte and im +3 classes then I end up in TT4. So can I compete in tt4 with the tte+points for mods or does that then mean I have to use the TT4 calculations? Quote Link to post Share on other sites
AZELISE 0 Posted May 18, 2017 Share Posted May 18, 2017 If you compete in TT4 you must use the TT4 calculator. Quote Link to post Share on other sites
