Sign in to follow this
sawguy
FS 944spec car
sawguy
SOLD, SOLD
Going to focus on my GTS3 car so the 944spec car has to go. Price $8k
New or Rebuilt in the last 3 years.
1986 body with 1983 motor. car was built in 2014, raced all of 2015, a couple of times in 2016/17. Has a Log Book and is good for 2017.
Chassis:
Hanksville prefabed roll cage installed by FlatOut Motorworx
Aligned and corner balanced by FlatOut Motorworx
Welded in Jack pads
Brake Master
Front brake rotors
Front and rear brake calibers
Paragon brake cooling kit
Stainless front & rear brake hoses
Hawk Blue brake pads front & rear
Braille Battery #1067
Windshield
Three sets of wheels
Engine:
Clutch Kit with pilot bearing
Clutch master & slave cyl
Oil baffle kit
Setrab oil cooler
Water pump and hoses
Rod bearing set
Cam/Balance belts with roller and guide plate
Paragon A/C delete kit
Alternator belt
Weltmeister throttle response kit
Fuel Injector, pressure regulator and damper
Rod bearings an connecting rod nuts
Camshaft position sensor
Suspension:
Manual steering rack with new boots
Koni shocks
Racers Edge Banana arm bushing Delrin
Racers Edge front control arm bushing
Weltmeister adjustable rear sway bar
Tarett adjustable front sway bar
RACERS EDGE, LOWER TORSION TUBE BUSHING SET, DELRIN
RACERS EDGE, UPPER TORSION TUBE MOUNT SET
POWER FLEX REAR AXLE CARRIER OUTER MOUNTING
ELEPHANT REAR MONOBALL FOR TRAILING ARM INNER MOUNT
ELEPHANT POLYBRONZE SPRING PLATE BEARING
Passenger rear wheel bearing
Interior:
MOMO Daytona Evo XL on Brey-Krause seat bracket on sliders (9/13)
NRG steering wheel with MOMO adapter
Window net (8/13)
Schroth belts (good unit 2019)
ESS fire system
Water temp gauge and sensor
Oil temp gauge and sensor
Oil PSI gauge and sensor
Sunpro tach
Voltage gauge
Mechanical main power on/off switch, with solenoid power on circuit
Spare Parts:
Heads
Brake calibers
Control arms
Rear axles
Gaskets
Hoses
Starter
Alternator
Brake rotors
Fuel rail
Fuel pump
And too much to list
pics here https://goo.gl/photos/31r6XaXEYmTDzYeN6
Share this post
Link to post
