jwilless Posted July 23, 2017 Share Posted July 23, 2017 (edited) Renesis Rotary Mazda Rx-8 Engine Package - $4k + shipping Almost everything you could want or need in a Renesis Race Package! Will not separate. 6 port motor freshly rebuilt by RP performance with all new Mazda OEM seals and gaskets. No engine oil or oil injection pump on this motor. It is set up as a dry sump motor with pre-mix fuel. I’ve swapped to a Peripheral Port motor on my Diasio 962R! Moroso Dry sump 3 stage oil pump – 10 hours since rebuild – Stock filter pedestal & filter housing included if you prefer. Comes with 2 cog belts. Flat plate oil pan currently installed. High pressure oil bypass included depending on your use. Good for 10 GPM and 120 psi. MicroTech ECU – includes ignition module and performance LS style coils, already tuned with a map to get about 260 HP at the flywheel. Complete wire harness included with relays and sensors. Programming Dongle and cable included. AEM Wideband O2 – includes 3 - O2 sensors Racing Beat Race Header – Coated with the White Lightning Swaintech exhaust Coating, Aluminum heat shield included. 3” V-clamp outlet Intake – 2 with large throttle body, tuned injectors, custom airbox and air filter Lots of extras with this package. All the hardware is there and it’s labeled. All the wires are labeled. There are lots of new extra gaskets, seals, injectors, water pump, stock coils, pick-ups, alternator with belts etc. You aren’t gonna find more Renesis engine stuff in one place. This would be great for a kit car or aircraft project Pictures below https://drive.google.com/open?id=0B4R1g9HnPNrRby1rdnlTMFNIOTA Contact Justin Willess at [email protected] 540-230-9047 Located in Aldie, VA Edited June 2, 2018 by Guest Quote Link to comment Share on other sites More sharing options...
jwilless Posted July 23, 2017 Author Share Posted July 23, 2017 Price drop to $7k Quote Link to comment Share on other sites More sharing options...
jwilless Posted September 4, 2017 Author Share Posted September 4, 2017 Price drop to $6k Quote Link to comment Share on other sites More sharing options...
jwilless Posted October 10, 2017 Author Share Posted October 10, 2017 $5999 Quote Link to comment Share on other sites More sharing options...
jwilless Posted November 24, 2017 Author Share Posted November 24, 2017 Correction - Seals are Mazda OEM Quote Link to comment Share on other sites More sharing options...
jwilless Posted December 18, 2017 Author Share Posted December 18, 2017 Price drop to $4999 Correction - Seals are Mazda OEM Quote Link to comment Share on other sites More sharing options...
jwilless Posted April 16, 2018 Author Share Posted April 16, 2018 Price Drop to $4900! Quote Link to comment Share on other sites More sharing options...
jwilless Posted June 2, 2018 Author Share Posted June 2, 2018 $4k + shipping Quote Link to comment Share on other sites More sharing options...
