Rob S. Posted June 13, 2017 Share Posted June 13, 2017 (edited) For sale is a 1993 Nissan 240sx S13 Hatchback (FL car, no rust and no accidents) racecar with an LS1 engine. Currently it is set up for NASA Time Trials TT3 class; 2775lbs (w/ 160lb driver, full tank of fuel and 50lbs of ballast) and 300whp w/ pedal stop. W/o pedal stop makes 365whp. Runs on 93 octane pump gas. Can also be run in ST3 or ST2 (w/o pedal stop and ballast). It has competed in the Great Lakes region for 10yrs in different classes and has won many events and set lap records. Car has been featured in Sport Compact Car and Modified magazines. Car has best of everything and been meticulously maintained. Please call/text (330-461-2093) or email me ([email protected]) if you have any questions. Thank you. Rob TT3 Lap Times Mid-OH Club Course - 1:35.9 Mid-OH Pro course - 1:34.1 Watkins Glen - 2.04.1 Engine/Drivetrain - Complete Fueled Racing Conversion Kit - LS1 (out of 2004 GTO, LS6 block, ATI damper, Katech tensioner, rocker arms w/ trunion kit) - Griffin radiator - Mocal oil cooler - Power steering cooler - T56 (out of 2004 GTO) - 3.54 FD with OS Giken LSD Chassis - Adjustable coilovers with Eibach springs - S14 front knuckle (larger wheel bearing) - Tein spherical bearing tension rod - Tein tie rod - Sikky 32mm adjustable hollow front sway bar - Whiteline 22mm adjustable solid rear swar bar - Rear SPL Titanium adjustable spherical bearing camber, tie rod and traction arms Brakes - Front - Wilwood 6-piston calipers - Rear – Wilwood 4-pistion calipers - Tilton proportioning valve for rear brakes Interior /Safety Equipment - 6-pt cage with Nascar bars on both sides - Fire suppression system - Handheld fire extinguisher - 3-qt Accusump - Sparco Evo seat - Sparco harness - Side and center nets - Oil temp, oil pressure and water temp gauges Exterior/Aero - Greddy Rocket Bunny kit (Front bumper from kit not installed but included with car) - Fiberglass vented hood - APR GTC-300 67” wing - Custom front splitter - Carbon fiber rear hatch w/ lexan Wheels - 18x10 Forgestar F14 $24500 OBO $20K price reduced Keywords: NASA, SCCA, RACING, RACECAR, RACE CAR, GT, ST, TT, TIME, TRAILS, ATTACK, REDLINE, AUTOCROSS, DRIFTING, 240SX, S13, S14, NISSAN, TRACK, DAY, LAPPING, HPDE Edited June 28, 2017 by Guest Quote Link to comment Share on other sites More sharing options...
Rob S. Posted June 28, 2017 Author Share Posted June 28, 2017 Price reduced - $20K Quote Link to comment Share on other sites More sharing options...
