Bcoffin23 Posted August 17, 2017 Share Posted August 17, 2017 Hi Everyone, I am extremely interested in TT4 then TT3 and so on. I have done 2 HPDE and 5 track days with various organizations throughout socal along with 4-5 autocrosses. This was all in a Miata NB, which I loved, but at 6'2 it isn't really a car I want to continue to put time/money into. My budget is 10k (initially) so I want to buy a car ~6k and spend the rest on safety/suspension/tires. This needs to be a car I can drive to the track. Currently I am considering: 350z e46 330ci 02-05 wrx g35 coupe Can anyone here shed some light on these cars, their recommendations/personal experiences, etc.? Thank you in advance! Quote Link to comment Share on other sites More sharing options...
kpearson Posted August 20, 2017 Share Posted August 20, 2017 You'll have an easier time with modifications with an E46 3-Series or 350z. However, first I would take a trip to one of your local NASA events. See what TT classes are competitive and figure out with your budget, which class you can fit in which has a decent showing. The worst thing you can do is get a car, then get in a class that has low participation in your region. Quote Link to comment Share on other sites More sharing options...
EricJo Posted August 20, 2017 Share Posted August 20, 2017 Did you know you can drop the floor 2" in a Miata? http://mazdaracers.com/store/product/70-floor-drop-panel/ https://www.advanced-autosports.com/collections/roll-cages-and-accessories/products/spec-miata-floor-drop Quote Link to comment Share on other sites More sharing options...
Arca_ex Posted August 21, 2017 Share Posted August 21, 2017 I'm 6'5" and fit in my caged NA Miata just fine. You just need to get the proper seat setup with a 330mm steering wheel placed at the correct depth. Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted October 17, 2017 Share Posted October 17, 2017 Did you know you can drop the floor 2" in a Miata? http://mazdaracers.com/store/product/70-floor-drop-panel/ https://www.advanced-autosports.com/collections/roll-cages-and-accessories/products/spec-miata-floor-drop Watch out for the 100 lb hit: TECHNICAL BULLETIN 1-29-16Mazda Miata Driver Seat Floor Pan Appendix A—Technical Bulletins for Specific Models/Items Mazda Miata (’90-’05)–TTB-TTF: The driver’s side floor pan may be modified to accommodate larger/taller drivers. All modification shall be contained between the transmission tunnel, driver’s side rocker, rear bulkhead and no more than 24” forward of rear bulkhead. The modification shall not extend below the factory floor stiffener/frame rail. The steel used in the modification shall be no thinner than .060”. All modifications shall be welded in place. This modification shall serve no other purpose other than seating position. The assessment for having this modification will be an additional 100 lbs of weight added to the vehicle’s base weight (or 100 lbs added to a Dyno Re-class if the vehicle is using a Dyno Re-class instead of the base classing table). (note for TT1-TT3, this modification would necessitate the Non-Production Vehicle Modification Factor) https://timetrial.nasaseries.com/rules-addendums-and-clarifications/ Mark Quote Link to comment Share on other sites More sharing options...
