FS: 1999 BMW M3- **SOLD**
dwc
 Share
**SOLD**
For sale is my 1999 BMW M3 coupe (E36). This car is in outstanding condition inside and out. As you can see from the maintenance list below, it remains virtually stock.
I am the 2nd owner of the car. The original owner was an older gentleman who lived in the Winston Salem, North Carolina area. He traded it at Flow BMW (Winston Salem) the end of February 2015 for a new M4. I purchased the car from Flow BMW the beginning of March 2015. So, the car has lived in North and South Carolina its entire life and has absolutely zero rust. The car has been garaged its entire life.
Details are as follows:
Clean title
Silver exterior/Black interior
3.2L I-6 engine
5-speed manual transmission
128,5XX miles
Sunroof
Tri-spoke steering wheel
Heated/power “Vader” seats
Rear seats fold down and have headrests
Wheels and tires are virtually new- installed 5,000 miles ago
ASC delete
Maintenance/upgrade list:
117,869- Power steering lines replaced, Tektar front & rear brake pads installed, rear parking brake shoes installed
118,200- Front & rear brake rotors (Centric) installed, Apex 75mm wheel studs installed, CDV deleted, air box baffle deleted, replaced trans fluid w/ Royal Purple Syncromax fluid, oil & filter change- Mobil 1 0w-40
119,000- Replaced cabin air filter, replaced OBC (time) bulb, installed X-brace
121,750- Diff fluid changed- Mobil One 75w-90, installed M12 diff mount bolt
122,400- Installed CSF aluminum radiator, Stewart water pump, thermostat, OEM composite thermostat housing, BMW coolant, upper & lower radiator hoses, brass bleeder screw, AC belt
122,489- Installed Rogue transmission mount, BMW center support bearing, BMW guibo, mid-pipe hangers, inner muffler hanger, rebuilt front drivers side brake caliper, bleed brakes (Motul 600 fluid), ZHP shift knob, Understeer short shift kit, delrin oval carrier bushings, shift lever foam bushing
122,602- Oil & filter change (Mobil 1 0w-40)
123,427- Installed Apex ARC-8 17”x9” wheels, 12mm front spacers, & BFG G-Force 2 (245/40ZR17) (square setup)
124,000- Installed Spal electric fan, rotated tires
125,000- Installed OEM auxiliary fan, 80/88* coolant temp switch, high speed aux fan relay, Motion Motorsports underpanel kit w/ radiator baffle
126,800- Installed Lemforder FCAB, RCAB, RCAB reinforcement shims, oil & filter change (Mobil 1 0w-40)
The car drives as new and is as clean as you will find. Car is located in Greenville, SC.
Price is $13,300-----**SOLD**
Thanks,
Daniel
**Photos should now be smaller and visible.
guestaccess.aspx?docid=1a458858d58004c2f932529ed70e1e36b&authkey=AcnInib29Y7An82EPt28DSw
guestaccess.aspx?docid=1ff7763d96f5a4b20a642a5f655725890&authkey=AXyNwy1juUmHZzFWybrgRT8
guestaccess.aspx?docid=1f09ea6be5e6a481a8a269408e2f4ce97&authkey=AbmYrtw4ME_omJ7mh8AxFp4
guestaccess.aspx?docid=122bca775dc714fd3b9803b1b817158c6&authkey=AXTkEMfP2sLEd4RYT88KL84
guestaccess.aspx?docid=1335980433cb7492781fd6930460d1eb7&authkey=AdbNwoTof2jFbPN40HEfg9U
guestaccess.aspx?docid=12b642118d42d4377a75116e5397e62b6&authkey=AVY5lB-EZVT3hwlVcgPZ5fA
guestaccess.aspx?docid=150c6e693e1f341f8b221a6c8bc6b8ef8&authkey=AX4Y5om5t6yco914A4cU0rY
guestaccess.aspx?docid=1cbcd7e8b6d474f90bc5305ce96aeab88&authkey=AYcYIvPzx6V9ji6GyG0Zb1U
guestaccess.aspx?docid=17c28c3ff557a4b3abcaebae2c127777f&authkey=ASGF82MdjTM8AFuMANj-txM
guestaccess.aspx?docid=17deff55c42d04bb28abaccad64bd373d&authkey=AbsyTb4HKigw38W9BUL67OM
guestaccess.aspx?docid=1153da704d74e4c24b854a0ac2b24acbb&authkey=AR1d4pSZo0czEp9CxDLKEbg
guestaccess.aspx?docid=1ad594ce2943f4e25a303245f166aba1a&authkey=AQ6-2ctkdG1slyAWhxmDSJc
guestaccess.aspx?docid=1dbabfa2d8aa94b08b2e7d51e750d3564&authkey=AeoI6jzLk-__0xILAFWCQxE
guestaccess.aspx?docid=1edb122018387444eb778e4ad11ba0ce8&authkey=AS1Pbh4zl8_5YSdxQDzIulE
guestaccess.aspx?docid=1ee75697bc9074139bd17dcdf7c1872d2&authkey=AbZGaUf7EfKxH9665Khi8sI
guestaccess.aspx?docid=1c40d831204424f43a88ef6c8836a31bc&authkey=ARgE7rNnFLRS8LVe8_tcnxk
guestaccess.aspx?docid=1274386a13799463b802d6ee718e1c8a8&authkey=Ad6t7M5uB1RYCc1e0sjbSL0
Thanks Ev, I didn't realize the photos weren't showing. I could see them fine, but I guess that's because I have permission on that forum.
Hopefully, they are visible now.
Daniel
  • 2 weeks later...
 Share
