kjbrew01 Posted November 2, 2017 Posted November 2, 2017 I have a 1989 supra that I run in time trials class TTC (now will be TT5). I haven't raced in the last 1.5 years however I am going through the car now to get it ready for next year. The car currently has 8 year old OEM replacement bilstein yellow shocks with 2.5" ID springs via a coilover conversion kit. I am looking at some options to get the shocks better matched to my springs Front springs are 1250 lb/in, front motion ratio is 0.5:1 (Shock:wheel) ie wheel moves twice as much as shock Rear springs are 550 lb/in, rear motion ratio is 1:1 Here are the options I have identified so far Send OEM replacement bilsteins or Konis out for revalving. Cost 6-800 Pros: Easy swap, low cost Cons: no gain in bump travel for front suspension, steel bodies are heavy. Cobbled together 2.5" spring setup/perches Custom valved circle track shocks from Afco Cost 900-1200 Pros: threaded body with spherical mounts built in, lots of valving available, shock adjustment, aluminum body Cons: likely twin tube construction, I am responsible for determining valving selection Custom built MCS TT1 single adjust shocks Cost $3000 with mounts Pros: proven brand in race shocks, shop setup valving, custom mounts provided with shocks, ability to upgrade to double adjust/reservoir as needed Cons: High cost Does anyone have any anecdotal experience with these various levels of shocks and what I could expect performance, lap time wise? I don't know if a MCS shock is worth 1-2 seconds over a OEM replacement style shock etc. I am considering going spec miata in a year or two so I am not sure tying up a lot of money in the MCS setup is worth it if the circle track or OEM revalves can get me some improvement. Quote
TurboShortBus Posted November 5, 2017 Posted November 5, 2017 IMO if the driver has been parked for a year and a half, then I would not recommend spending any money on the car, other than regular maintenance items; investing in seat time and consumables would be a better idea. Besides, if you might to go another car and class in a year or two, you will get pennies on the dollar then for any speed parts you buy now. Mark Quote
