downingracing Posted November 11, 2017 Share Posted November 11, 2017 2006 Pontiac Solstice - Currently running in the SCCA Touring 4 class. This is a great track/race car. Easy to drive and easy on parts. This is a true Z0K package car (1 of 16 built in 2006) - Clear Ohio Title with only 5,300 miles from new (Car has been a race car since mile 1). This car started life in the SSB class and currently competes in the Touring 4 category. Original and current SCCA logbook with current annual tech inspection and several races a year for the past few years. Car is sitting as it came off the track from the 2017 SCCA RunOffs at the Indianapolis Motor Speedway (finished 22nd in T4 of 39 with old tires). Min. weight for the class is 2850#. Engine: 2.4L 4-Cyl (stock per T4 rules, but has a tune) K&N Cold Air Intake Kit Custom exhaust Trans: 5-speed (stock) GM clutch/PP/Flywheel (new in 2016) Suspension: Stock Z0K Solstice Suspension (Shocks and Springs) Z0K Sway Bars front and rear Limited slip differential Brakes: Stock F&R Custom fresh air brake ducts Factory ABS Interior: Custom roll cage Kirkey seat (mounted on the floor and fits 6'4" 260# driver) G-Force cam lock belts (FIA good through 2018) Competition steering wheel (removable for easy exit) Handheld extinguisher Left window net Wheels/Tires (Rims are Stock size 18x8): 1 set (4) of stock rims with old (old!) race tires 1 set (4) of stock rims with brand new street tires (rain tires) 1 additional stock rim (single) Other: GM Performance hard top Custom tow hooks (front and rear) Wired for radio setup (radios not included) Full set of GM service manuals included CEL is on (has been that way since I've owned it and doesn't impact performance) Transponder and AIM SOLO NOT included With tires, a transponder, and a fluid check/change - the car is track ready. Asking $12,900 obo - Trades considered. Spares package available/negotiable with the sale: Engine (complete - disassembled) Two transmissions Four corners of suspension (control arms, hubs, brake calipers, axles) Differential GXP sway bars (not T4 legal) Lightweight flywheel and racing clutch (used & not T4 legal) 1 set (4) (+1 extra) PF01 lightweight rims (18x8 ~18# each) Pair of new doors (painted shells) Pair of new quarters (painted) Pair of new fenders (painted) Pair of used fenders (painted) Stock exhaust Grill insert Several sets of racing brake pads New rotors (all four corners) Spare ECM One spare headlight Spare Z0K shocks (modified - not T4 legal) Braided brake lines (new) New Hub (all four are the same) New motor mounts New water pump Misc. belts New brake booster (x2) New brake master (x2) Many other misc. parts Photos in the craigslist ad here: https://columbus.craigslist.org/cto/d/2006-pontiac-solstice-z0k/6337680126.html Quote Link to comment Share on other sites More sharing options...
downingracing Posted November 15, 2017 Author Share Posted November 15, 2017 Pending... Quote Link to comment Share on other sites More sharing options...
downingracing Posted November 19, 2017 Author Share Posted November 19, 2017 Sold. Quote Link to comment Share on other sites More sharing options...
