1992 Nissan Sentra SE-R race car and 2013 2-axle trailer
derrick
SOLD
RACE CAR
– Raced in NASA SoCal and at National Championships from 2006 to 2012
92mmp11.jpg?w=1060&h=&zoom=2
92mmp2.jpg?w=1060&h=&zoom=2
ENGINE
– Custom built sr20de – 2.0l Inline 4-cylinder
– JWT cams (spare cams)
– JWT custom programmed ecu (spare programable ecu)
– Race header
– Custom K&N cold-air intake
– Unorthodox pulleys
– Nismo limited slip differential
– Fidanza lightweight flywheel
– Additional spare rebuilt spare sr20de engine
SUSPENSION
– Bits & Pieces Motorsports custom Koni 8611
based coil-overs
– Eibach springs
– Bits & Pieces Motorsports offset rear strut hats
– Ground Control front camber-caster plates
– Unbalanced Engineering bump steer kit
– Progress custom 1-inch rear 3-way-
adjustable, solid sway bar
– Energy Suspension urethane bushings
TIRES
– 225/45R15 Hoosier R6s (old)
– 2 sets of wheels
BRAKES
– Fastbrakes 11 inch 4-piston calipers kit
– Fastbrakes stainless-steel braided lines
– Hawk brake pads
MISCELLANEOUS
– 7’s Only/Eric Sutton custom roll cage
– Raceonusa carbon fiber hood
TRAILER
– 2013 Carson Trailer
– 14'
– 2 axle
– Electric brakes
  • 1 month later...
I can't find any results from you racing at MidOhio NASA Nationals especially in 2011 or 2012 (and I would have remembered seeing your SE-R there) So other than Miller in 2010, do you have any results from when NASA Nationals was at MidOhio? I'd be curious to see your lap times from MidO if yes. Thanks
Only ran Nationals in 2009 and 2010 at Miller.
Okay?
You might want to reword your initial ad then. It reads "and at National Championships from 2006 to 2012"
