NASA Tire Section Width - User Contributed Database
MemphisRob
 Share
I think it might be helpful to hear what some different tire and wheel combos are producing as our new NASA Tire Section Width.
If you share the details on your widths I will update this post to consolidate and create a database. I understand it won't be perfect and it will be on the honor system, so consider that before dropping a bunch of coin.
Measured NASA Section Width - Tire Size - Tire Brand - Tire Model - psi - Date Code/Age - Wheel Size - Wheel Brand - Wheel Model - Method of Measurement - 23mm/30mm deep
???.?mm - 225/45/17 - Bridgestone - RE71R - 32psi - 2015 - 17x7.5 - BMW - OEM - digital calipers - 30mm deep
From 6.1.2 of the 2018 Rules - https://nasa-assets.s3.amazonaws.com/document/document/12742/ST5_Rules_2018--v1.1--11-29-17.pdf
“NASA Section Width”
DOT tire width is determined by a measurement of the “NASA Section Width” of the largest tire (if staggered sizes) on the vehicle in post-competition impound/inspection, without changes to tire inflation (may be allowed to cool to pre-competition pressure). The tire may be measured while off or on the vehicle at any location not affected by ground contact sidewall deflection. A tire's NASA Section Width is the measurement of the tire's width from its inner sidewall to its outer sidewall using the NASA Section Width tire measurement tool(s) (excluding any protective ribs, decorations or raised letters) at the point 30mm deep to the tread surface on a new tire for vehicles 2400 lbs. or greater, and 23mm deep to the tread surface for vehicles less than 2400 lbs.
I will update this post with new measurements as they come in. If there is a measurement already listed similar to yours please contribute your measurements as well. There will likely be some variances like worn shoulders or wheels that don’t run “true” to size...so the more data points the better.
https://www.dropbox.com/s/l4oa9bjm4qvnfbn/Photo%20Dec%2011%2C%206%2012%2038%20PM.png?dl=0
So, I ordered a Neiko 12” digital caliper from Amazon and checked some tires in the garage. I did this really quickly and didn’t check psi...but I figured I could update later.
One compromise I made was using my stud finder as a “spacer” to reduce the caliper “tongs” measurement to about 3cm. I’m considering cutting the “tongs” to exactly 3cm to be more exact with the measurement.
Anyway, here are some preliminary findings and measurements. I wil round up on millimeters.
Both the 225/45/17 and 235/40/17 Maxxis RC1 on an identical Borbet 17x8” Wheel are just about the same 229mm wide.
unmounted it is 241mm wide at 3cm
17x8.5” D-Force LTW Wheel is about 234mm wide at 3cm
17x8" Borbet it is 229mm wide at 3cm
17x8" Borbet rim it comes in right at or maybe under the 226mm threshold at 23mm (could be a cheater tire for the sub 2400lb cars?)... might be fine as is on 8" wide but it is close for sure... on a 7.5" wide rim I am just about sure it will be well under the 226mm.
225/45/17 Bridgestone RE71
Unmounted this is over 226mm at 3cm, but under 226mm at 23mm.
17x7.5” OEM BMW Wheel is about 221mm
Honestly, it looks like tires with a much more “squared” shoulder will have a nice advantage in the way these are measured 3cm down the sidewall. Rounded shoulders give up quite a bit of contact patch on each side. Also, it looks like the wheel width will be a significant variable on how wide or narrow a tire will run. I measured the 225 RE71 on a 7.5” wide tire at 211mm at 30mm deep but at 23mm deep it would be even narrower...so well within the 226mm Section Width limit for sub 2400lb cars.
https://www.dropbox.com/sh/7b0pzrq0l51pq0r/AAD-kqNTQ0dFFgz07CmKulLta?dl=0
Measured NASA Section Width - less than 266mm (probably 5 mm to spare easily)
Tire Size - 245/40/18
Tire Brand - Hoosier A7
Tire Pressure / Date Code - 26 cold/1417
Wheel Size - 9.5" rim
Wheel Brand/Wheel Model - APEX ARC 8
Method of Measurement - 266 x 30 mm NASA Template
Thanks Clavette.
I was wondering if the Hoosier 245’s would still be under 266mm on a larger than 9” rim.
Since 9.5” wide rims still aren’t at the limit, I hope someone measures a 245 on 10” rim.
Thanks Clavette.
Someone measured the 245/40/18 on a ten inch with a cardboard template. You can find the pictures in the NasaMa TT Facebook group. Fits questionably, also its not a arc8
Looks like the NASA MA folks have been busy checking tires... Thank you very much to the people that contributed.
Anyway..these are from the Facebook page.. I figured I'd add them here.
225/45/17 R7 on 17x8 tsCUk9P51nzOkiTvn4jTer633i_TghXu7G7T9hLNn_M?size=32x32&size_mode=5
225/45/17 R7 on 17x10 635Jo5x4sABb-Sgb56QWdZ8eyx742hZfhstQOiknIqw?size=32x32&size_mode=5
245/40/17 A7 on 17x10 Zhrm8qFbkpDKMmYvk1BNRZ9m0HqKBcmEEFVzCBFIU7w?size=32x32&size_mode=5
245/40/18 A7 on 17x10 7Z9zkkLj-i177au_Mm2cHzKUKO-Ci7Piwom75jeNO5o?size=32x32&size_mode=5
255/40/17 RC1 on 17x10 3Na7-VqK67B3Z2JEZhuFRJCkwHFi4yF-DH0SodNObeQ?size=32x32&size_mode=5
  • 3 weeks later...
Merry Christmas to all!!
Anyone do some tire measuring in the last couple weeks? Or is there another forum or Facebook group that has posted any more widths or other sizes?
Any contributions are appreciated.
Thanks.
The pictures don't seem to work. Can you please re-share or re-link them? Or, say which passed and which didn't? Thanks!
I can't see them on my iPhone but I can see them on my laptop... maybe I need to upload them to something other than dropbox.
Can you see this image?
That works, thanks!
Bummer that the 245/40/17 Hoosiers are over the 266mm template on a 17x10. Darn.
Thanks for making a spreadsheet.
Interesting that a 245/40/17 A7 fits the 266 on a 10" but the same size R7 does not.
My theory is that the apex rims run wider than most.
Here is a 18X10 I have sitting
39378556681_f54788ab33.jpgUntitled by patrick cornwall, on Flickr
39378551281_5afc683c77.jpgUntitled by patrick cornwall, on Flickr
Here is a 225/40/17 R7 on a apex arc8 17-9.5
Just fits in the 257 template
38501053295_565a71e5a5.jpgUntitled by patrick cornwall, on Flickr
Thats all I can contribute for now. If anybody has a 255/35/18 on a 10" arc8, I would love to know if they fit in the 282 template. Greg seems to think it won't fit. That would be unfortunate because its the ideal size for the e36, being that its not nearly as tall as the 275/35/18
  • 3 weeks later...
  • National Staff
NO GO on the 266mm/30mm (by about 1-2mm)!
Hoosier R7, 245/40x17, 30 & 35 psi, APEX ARC-8 17 x 9.5" wheel
I definitely wonder as above if this wheel is just bigger than other 9.5's?
Going to get a 9" and retest, but suspect it might fit--just needed a little narrower....
I have these tires on other 9" wheels and other 8.5's, and they are compliant by 2-5mm.
So, the new system will not only catch tires that are not as advertised, but wheels that are larger than listed as well....definitely evening out the playing field for all.
  • Like 1
We did a measurement on our ST3/E0 E36 18x10 Apex ARC 8 & EC-7 wheels and 255/35/18 Hoosier R7. It did not appear to fit the 282mm template, but just barely missed, by maybe 1mm, that is a pretty tight tolerance. Is 1mm of section width really that much of an advantage?
I know going back into the PT classing history journals, the 255 has always been the "cheater size". But this is ST...not PT? The primary reason for using this size for us was actually the height of the tire. Similar tread width (if not the same) between the 275/18 and 255/18, the 255/18 has a little more rounded shoulder than the 275/18 I believe (I don't honestly know which is better? square vs. rounded?). The 275/18 tire, however, is much taller (25.5" vs. 24.8"), which means you have to raise your ride height and now your cg.
Luckily for people who run 17" wheels, as in the 275/17s (which qualifies for a .3 modifier), they offer a lower profile 275/35 which maintains a tire height of 24.7". But for 18s, the 275 tire size just sucks for the E36. Maybe we lobby Hoosier to relabel the 255 to a 275...
(Full disclosure, in my sprint/TT car, I run 285/18s, so this new rules doesn't change much there)
I don’t really see how the 275/17 is going to work, with a listed section width that’s even larger than the 255/18. 11” vs 10.8”
This is a real headache trying to find a tire wider than the 245 on a 9” rim to run on a e36 (for tt contingency). Yes there are wider options, but they are all really tall. Meaning, really hard to fit and huge gearing reduction.
Any chance of ammending the 282mm to say 286 or something?
  • National Staff
Our testing of the 275/17 and 18 Hoosier on a 10" wheel had no problem fitting the 282mm tool.
Has anyone measured 245/40/15 Hoosier on a 10" wheel with the 266mm template? I am suspecting that it will be very close as it runs narrower than both the 245/40/17 and 245/40/18 Hoosiers with the 17" being the largest. The 18" Hoosier seems to have cleared on 9.5" Arc wheels which might run large for the given size so could almost be 10" wheels.
Good to hear. I hope it was measured on a apex wheel haha
  • National Staff
Unfortunately not.
I'm going to test out the 9" Arc-8 with the 245/40 x17 R7 in the next few days. I've got my fingers crossed--should be okay--just missed on the 9.5" by 1-2mm.
  • 2 weeks later...
Unfortunately not.
Any update to testing the 245/40/17 R7 on a 17x9?
  • National Staff
I tested the 9" Arc-8 with the 245/40 x17 R7 with a date code of 2317, and it fit the 266mm tool by less than 1mm at 35 psi.
I'm a little concerned that there may be a significant variance between tires of different date codes of that specific model (although the later codes seem to be okay). So,
I suggest checking your specific tire. If it measures 275mm off the wheel, it is unlikely to pinch down to 266 by using a 9" wheel. If it is 270-271mm off the wheel, I would
think it would fit.
  • 1 month later...
I purchased both a 245/40/18 and 245/35/18 Hoosier R7 and neither of them would clear the 266 template dismounted. Not sure how someone got this to work on a rim with pressure???
It seems it will depend on the wheel width. What size wheel were you planning to run with?
Here was an example for me..
Unmounted
over 226mm at 3cm
under 226mm at 23mm
Mounted
~221mm on 17x7.5” OEM BMW Wheel
Also, if anyone with measurements would please post your results here I will compile the new data added in the last couple months and update the spreadsheet accordingly. Thanks in advance.
 Share
