Techinical Bulletin--Avg HP Calcuation--F/I 12-6-17
  • National Staff
TECHNICAL BULLETIN 12-6-17
Average Horsepower (Avg HP) Calculation
7.2 Average Horsepower Calculation
7.3.3 For vehicles with a redline less than 6000 rpm and all Forced Induction vehicles:
The three (3) highest data points of the above sixteen (16) will be used in the calculation below:
Avg HP = [Max HP +(sum of the three highest data points)] / 4
  • 4 weeks later...
Greg, clarification please.
1. Does the TB 7.3.3 apply to TT or is this just for ST/SU?
2. If it does apply to TT, regarding F/I vehicles, is that just for F/I vehicles with less than 6000 redline, or all F/I vehicles, regardless of redline? Believe the answer is ALL, but asking to be sure I understand clearly.
3. Will a new Dyno Certification Form be coming out or are we just to use the current one on site?
Thanks
- TT and ST use same rules so it does apply to TT.
- it states all but not sure why. FI is the easiest to manipulate the hp curve and there are definitely FI engines that rev well above 6k rpm.
Greg, what is the reason to use only four hp points for all FI engines? Thank you.
Posted (edited)
Yea was pretty sure it applied, was just kinda hoping it would'nt. Did a rough calculation using last years dyno data, under the 4 pt rule my avg. hp, will increase about 10 hp, which means less weight I'll be able to take off car...boo-hiss.
  • National Staff
Rob, you answered your own question. It is the easiest to manipulate.
If it’s easily to manipulate, you’d want to take more points to cover a larger range of rpm for the average, not less points. If you agree FI is the easiest to manipulate, “all FI” should be added to 7.2.1 not 7.3.3. What do you think? Thank you.
Less data points make it harder for FI guys to manipulate their average HP. For example, if you only use a 1500 RPM powerband because of your gearing, you can drop the boost elsewhere to manipulate your average HP calculation. More data points would give them an advantage.
You're correct to an extent. This only makes sense for turbocharged cars, not all FI.
There are plenty of ways to manipulate boost with a supercharger...
https://www.google.com/search?q=supercharger+boost+controller&rlz=1C1CHFX_enUS591US591&oq=supercharger+boost+controller&aqs=chrome.0.0l6.2848j0j7&sourceid=chrome&ie=UTF-8
