Sign in to follow this
centerville
'03 Mustang Cobra
centerville
03 Redfire Mustang Cobra #4591/8394 (1-8-03 build date)
2nd owner, 39K miles, always garaged, meticulously maintained, have all receipts & documentation (including window sticker and brochure). This car is set-up for the track. Very fast and very reliable. Very well set-up with attention to consumables.
BRAKES
Wilwood race kit front. SL6 calipers (6 pistons). 2 piece 13” slotted Wilwood rotors. 2 sets of hats.
Maximum Motorsports IRS rear brake kit. Wilwood 4 piston calipers. 2 piece floating 13” slotted Wilwood rotors.
Wilwood SS brake lines.
Motul Brake Fluid.
3” brake cooling ducts in front. Kenny Brown rotor ducts.
Custom 2” rear brake cooling ducts.
Wheels and Tires
2 sets of 17x9 Steeda Ultra-lites.
1 set of older 275/40/17 Nitto NT01’s.
Exterior
Mach 1 side scopes.
Saleen rear spoiler.
Tiger Racing fiberglass hood w/ custom reinforcement.
Flush mount Aero-Catch hood pins.
Hinged tow hooks front and rear.
Interior
Momo steering wheel w/Sparco quick release hub.
Sparco pedal covers w/ custom bent and welded gas pedal by Racecarbuilders for heal-toe. I rmoved this but still have it.
Dead pedal modified by Racecarbuilders for quicker foot movement to clutch pedal.
Sparco Evo 2 (FIA) driver’s seat w/ custom seat rail by Racecarbuilders. I added sliders to drivers seat.
OMP (FIA) passenger seat w/ custom seat rail.
6 point Schoth seat belts.
I-port roll bar camera mount.
Braille 18 pound battery w/ holddown mounted behind the passenger seat.
Custom power disconnect switch.
Trackmate GPS, timing, and data system w/ lap display.
Custom gauge pod w/ water temp., fuel pressure, and oil temp. Autometer gauges.
Oil cooler fan and differential cooler on/off switches.
Fire extinguisher.
Parking brake removed.
Sound deadening removed.
Interior panels and carpet removed.
Cooling
Fluidyne radiator.
Full Evans cooling kit w/ remote oil filter (Fram HP1) and thermostat relocation.
Mocal oil cooler w/ Spal fan.
Custom alum. boxed in radiator w/ SS mesh over grill openings.
Evans high performance water pump.
Afco heat exchanger.
Chassis
Steeda tubular sub-frame connectors.
Custom RaceCarBuilders road race roll bar w/shock tower bracing.
Lakewood driveshaft loop tied into the sub-frame connectors by RaceCarBuilders.
Jacking plates tied into sub-frame connectors by RaceCarBuilders.
Sub-frame reinforcement by RaceCarBuilders.
Steeda strut tower brace.
Custom tie-down hooks front and rear.
All bolts painted to montior backing out.
Rear Suspension
Steeda differential cover brace.
Steeda IRS mounting braces.
Maximum Motorsports steering arms w/ bumpsteer kit.
Maximum Motorsports IRS Race shock mounts.
Maximum Motorsports Bilstein Race 2 shocks with coilover kit.
Maximum Motorsports and Full Tilt Boogie bushings throughout.
Full Tilt Boogie adjustable camber bolts.
Full Tilt Boogie custom hubs (zinc plated) and bearings w/ 3” ARP wheel studs.
Full Tilt Boogie adjustable swaybar end links (not installed).
Full Tilt Boogie cross axis joints.
Ford Motorsports 3.73 gears.
New Torsen T2-R differential.
Custom differential cooler w/ Tilton pump.
Ford Motorsports 75W-140 gear oil.
Front Suspension
Maximum Motorsports K-Member.
Maximum Motorsports offset control arms w/ delrin bushings
Maximum Motorsports steering rack solid bushings.
Maximum Motorsports solid motor mounts.
Maximum Motorsports race 2 Bilstein shocks w/ coilover kit.
Maximum Motorsports sway-bar end link kit.
Maximum Motorsports bolt through bumpsteer kit.
Maximum Motorsports Sway-bar relocation kit w/ poly bushings.
Tilton hubs (USA) w/ Moroso studs. Brand new set of hubs with studs installed as spares.
Steeda caster/camber plates (alum. 4 bolt).
Ford Motorsports 94-94 Cobra sway-bar.
Engine
Custom tune for track by Thunder Autosports w/ Diablo chip.
Diablo mafia.
Metco inter-changeable lower crank pulley (stock size) w/ bracket.
Metco idler pulleys.
Metco supercharger belt tensioner pulley.
Steeda 2.93 inter-changeable upper pulley.
Steigmeier custom road race port, balanced and blue printed total rebuild w/water cooler snout.
Intercooler has been removed and cleaned a year ago.
Steeda oil separator (driver side).
Sean Hyland oil separator (passenger side).
EGR delete kit.
Head cooling mod.
NGK plugs and new spare set.
Ford Motorsports Ford GT coil covers.
UPR fender air filter (K&N) relocation kit.
Accufab throttle body and inlet.
Mobil 1 (10-30)
A/C removed from firewall forward.
Exhaust
JBA titanium ceramic shorty headers.
New Pypes SS x-pipe.
Steeda catback exhaust w/ Borla mufflers.
DEI exhaust wrap under differential.
Transmission
Freshened up 1 year ago. CF sincros
New Centerforce duel friction clutch.
Redline D-4 ATF.
New Ford Motorsports Alum. Flywheel.
Ford Motorsports Alum. Driveshaft.
Maximum Motorsports clutch cable with firewall adjuster.
BBK clutch quadrant.
Steeda comfort shifter w/ custom relocation bracket to move the shifter back.
Extras
Many are included, pads, rotors, brake oil, some stock parts, etc....
Asking 17k
I have a CMC car so this one has to go.
Car is located in Haltom City TX.
Pics coming....http://s1021.photobucket.com/user/UB70/library/2003%20Mustang%20Cobra
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
