gtroester Posted January 29, 2018 Posted January 29, 2018 '86 Chassis, '88 Drivetrain - SP1, 944-Spec prepared Located in Salt Lake City, Utah Contact: Greg Troester - gregt1732[at]gmail.com Sold w/o title (retubbed car in 2016) but have signed bill of sale from chassis owner. This is an excellently-prepared race car. Turn-key and ready to go for the 2018 season with PCA, NASA, SCCA, or POC. I've built the car up from 2012 today, with many improvements (see list below). I'm selling the car after a successful 2017 season in order to move to a different platform. Please contact me for more background and to see the car. Pictures: https://1drv.ms/f/s!AjVtLrdY5Lstlwa9jIUTcmWap3Vf Chassis/Body: 2016 – retubbed w/ fresh paint inside and out, Clear Bra on entire front of car (except bumper) – 1/4 of the way up the hood and fenders 2016 – New windshield w/ tear-offs (2 intact) 2016 – winner of IRPCA “Best Prepared Porsche” award 2017 – Fresh paint on both sides, quarter panels, and air dam 2017 – New OEM air dam 2017 – Lexan quarter windows installed – NASA Legal Hood pins Glass hatch does not leak! Windshield wiper motor intact w/ wiring – includes OEM wiper controller Drivetrain: 2012 – ’88 Motor, injection, electronics – rebuilt by Motorsport 1.5 full race seasons on the motor since built - 3-5 DE weekends on it prior to that Cross-drilled crankshaft Lindsey Racing oil pan baffle kit 951 Oil Filter Console & Cooler, ducted from fog light hole (tested this – saw 10-degree improvement over placing this in the bumper) 2.5” Exhaust from stock headers – straight-pipe to muffler 2018-legal ram-air intake w/ K&N filter 2013 – New Sachs clutch kit in 2014 – all components replaced New flywheel New T/O bearing, rear main seal, clutch fork bearings, slave cylinder 2013 – rebuilt transmission by RSR Motorsports 924S transmission, short 5th gear Factory Limited Slip Always run with Swepco fluid – shifts great! 2016 – Torque tube bearings replaced, balanced the torque tube rod - $500 in parts/labor, excluding what it takes to pull the tube itself (~30 hours to R&R, as you all know!) Suspension / Brakes: 1988 Suspension setup – 944 Spec Legal 400# Front Springs, 30mm Rear Torsions Koni Yellows front and rear 951 M030 Swaybars, rear is adjustable 2016 – NEW Porsche OEM A-Arms 2016 – New LF spindle 2016 – Corner balance and alignment setup work w/ Tatum Racing Brakes: Brake ducting to both fronts Hawk DTC-60 Fronts Hawk DTC-70 Rears 2017 - Cross-drilled rotors on the front (less than half a season on them) Solid rotors on the rear Safety / Interior: 1.5” Hanksville Hotrods weld-in cage Nascar bars on driver’s side, straight bars passenger side Painted with car in 2016 Helicopter-taped the bars to avoid scuffing paint, tearing suit on driver ingress-egress Sparco Pro-Racer Hans XL seat w/ back brace & sliders GForce camlock belts – Expire in 2020 Handheld fire extinguisher Wired for CoolShirt Radio harness included – need to buy your own base-station or handheld Detachable steering wheel w/ PTT button (radio) Dash lights wired Kill Switch - Electronic solenoid-style - Kills all power w/ a low-voltage switch, saving battery from parasitic drain. Switches on interior and exterior OEM Dashboard Added Oil Temp Gauge – space for two more aftermarket gauges if you’d like. Custom-fabricated aluminum gauge panel Spares & Extras: 1 Extra set of 15” Phone Dials w/ a good set of practice Toyo RRs ’88 Engine – mostly complete – spun rod bearing in 2012, haven’t disassembled yet A-Arms (left & right) Awards & Accolades: 2017 NASA Utah Season Points – 3rd Place, mostly 2nd place finishes 2017 Utah 6-hour Enduro – 3rd Place – E3 Class 2016 – Best Prepared Porsche – Porsche Club of America, September race Track records: Spring Mountain “Mansell D” – Porsche Owners Club Utah Motorsports Campus “West” – NASA Utah (knocked off by a few tenths this year) Utah Motorsports Campus “Outer Loop” – Porsche Club of America Pictures: https://1drv.ms/f/s!AjVtLrdY5Lstlwa9jIUTcmWap3Vf Quote
