TT5: Hood Venting
truegearhead
  • National Staff
Am I correct in that hood venting as stated in the rules includes vents used purely for downforce?
Cheers
"5) Hood replacement/modification for venting and/or weight reduction (“aero”
hood pins are permitted)."
"If not using the BTM Aero Modification Factor, aerodynamic parts/devices/aides
shall be limited in ST5 to the following:...."
So, if you mean that venting your hood does allow for some change in downforce, then that would be okay as a side effect of venting. If you mean a vent that has an actual spoiler or foil or air dam of some type built into it that provides direct downforce, then it would not be okay. Also, I don't know that any hood vent is "purely" for downforce, as there would be some cooling effect if cooler air is moving past the engine.
Cheers
It’s a mid-engine so the engine cooling argument will be tough to say the least.
  • National Staff
Cheers
In that case, wouldn't the front be a trunk compartment, and putting a vent in the hood would not do anything (unless you did a modification to the floor of the compartment for aero purposes that is not listed as permitted).
I think I could argue the hood is in the front always but you’re right about modifying the floor. I would have to cut into the front trunk which doesn’t sound legal. Guess I’m stuck, I’m trying to find some front downforce to allow for a balanced aero package but with the a-arm penalty and mid-engine penalty I can’t afford the splitter penalty.
