[email protected] Posted February 14, 2018 Posted February 14, 2018 I'm looking to sell my 1998 AIX Mustang Cobra. The car is as turn key as it gets. Fresh Motor, trans and rear end with two full race weekends on it. Car is fast and reliable. Griggs racing fabricated and installed the suspension. The car is competitive and has full aero. Car weight is 3000LBS with 195lbs driver and full tank of fuel. Please email for details and pictures. Car is located in the Boston area and I can arrange to ship at buyers expense. looking to move this car out as soon as possible and I am motivated within reason. I'm sure I missing something.Would be a great car for someone that needs something that's ready to go. Please note the following: Chassis 1998 Ford Mustang Cobra Griggs inner and outer sub frame connectors 120 Wall Dom through the firewall full cage with foot box protection Cage is painted Aero AJ Hartman rear Chassis mounted adjustable 72 inch wing Front removable with 4 hood pins 2000 Cobra nose with separate splitter Dash Fabricated aluminum dash all analog autometer Ultra light white gauges Tach, Oil pressure, oil temp, and water all easily readable Interior Completely gutted painted Custom Fabricated steering column with Momo quick disconnect wheel Aluminum fabricated sub floor on drivers side Kirky Road racing seat Simpson FIA 6 point Harnesses valid through 2019 Shroth window net Simpson right side net wide angle cage mounted rear mirror On Board fire suppression SPA AAAF 6 nozzle Two on the interior, Three on the Motor and one out back on the fuel tank 3QT Canton Accu-Sump Custom switch panel within driver reach Cool Suit hard wired into switch panel with weatherpak quick disconnect Maximum Motorsports Manual fully adjustable brake pedal Brakes Front Wilwood Wide version 6 piston SL-6 Calipers with two piece rotors and hats custom fabricated ducted and vented Rear stock cobra Aggressive Wilwood pads matching compounds Suspension Griggs Tubular K-Member Griggs World Challenge fully adjustable front and rear control arms Griggs Severe Duty Watts Link Griggs Severe Duty Torque Arm Griggs Coilovers front and rear with Koni Double adjustable Shocks and Struts Griggs Caster Camber plates Trans Tremec TKO cleaned freshened with 2 race weekends on it Quicktime SFI bellhousing Aluminum Flywheel New with two weekends on it Clutch stage 3 Macloud with two weekends on it Rear End 8.8 Torsen T2R with 327 gears freshened with two weekends on it Motor 500 RWHP Ford Racing Boss 363 completely rebuild and freshened with no cost spared with two race weekends on it. Motor is strong and pulls hard. Three sets of wheels, one set of 1995 real Cobra R Wheels two sets of Weapons Set of Toyo RA1 wets One set of Hoosier R7's with two race weekends on them Could sell with steel open trailer Asking $15000.00 for everything motivated seller and need to move it fast. Contact Seller at [email protected] Regards Quote
