bojets Posted February 22, 2018 Share Posted February 22, 2018 Updated price added engine information. 2008 Mustang GT American Iron Race Car Race winning podium car in every category entered. 2008 Body in white with Watson Racing cage. Zero time 351 cubic inch pushrod motor custom built in 2016. Plenty of math and science put into the design specifications of the engine. AEM carburetor. Currently tuned to 375hp and 375 lbs of torque to comply with the power to weight rules. One piece aluminum driveshaft The engine was completely gone through at the end of 2016 to see what we could do better. Installed larger capacity Edelbrock water pump. Mechanical, fuel pressure, oil pressure and water temp gauges with braided lines. ATL fuel cell installed 2016. Koni 2800 Dual adjustable shocks. Rebuilt by Koni spring 2016 G-Stream rear wing. Multiple end plates available Custom front splitter built to N.A.S.A. Technical specs. Full body repaint August 2016. New windshield installed August 2016 Full fire protection system installed 2017 Three sets of wheels with Toyo Ra1, 1 set of mounted rain tires. 1 set of unmounted Ra1’s all has less than four heat cycles. Dart SHP Big Bore Block Scat Custom Rotating Assembly 4.155" CP/Carrillo Pistons 5.400" H Beam Rods 3.25" Stroke "lightweight" 4340 Forged Crankshaft Total Seal "Max Seal" Gapless Top Ring Pack 9.85:1 Compression Ratio 353 Total Cubic Inches Canton Pan and Pump Trick Flow 11R CNC Ported Cylinder Heads Custom "Machinehead" Hydraulic Roller Camshaft Ford Motorsports "High Speed" Roller Lifters Trick Flow 1pc CrMo Pushrods Jim Miller Rocker Arms Cloyes Timing Set Romac Aluminum Damper Edelbrock "Victor" Water Pump Professional Products Dual Plane Intake Manifold Custom AED 650 CFM Carburetor ACT "Prolite Xact" 14.7lbs Billet Steel Flywheel ACT Aluminum "Sport" Clutch Cover ACT Solid Hub 6-Puck Disk BBK 1.75" Long Tube Headers Current RWHP 375 with current 650 Carburetor and Manifold Has Dynoed at 393 RWHP with 750 Carburetor and Manifold Dyno at 415 RWHP with "Victor" single plane and 750 Carburetor The car was built with the intention to run in multiple classes with little conversion. The car was not raced in 2017 but is started and run on a regular schedule. $30,000 Pictures available upon request [email protected] Quote Link to comment Share on other sites More sharing options...
