Question about installing a 5 point harness system
I am currently ordering an Autopower 4 point roll bar and my car currently has a Sparco Evo II seat. Can anyone tell me how do I install a 5 point harness into a 2005 Subaru STI? I understand how to do the shoulder and lap harness but the one that prevents you from submarining I'm a little confused about. Is it legal to mount it to the sparco seat base? This will also be my first time running in an HPDE event and I just want to make sure to have my car up to par for tech inspection.
While it may pass, I recommend you go through the floor under the seat. This way you are being held in by something other than the seat. You can get one of these, and a clip so install and removal is easy
  • 4 months later...
Definitely don't mount the anti sub strap to the seat. It has to be mounted to the floor or at a minimum to the bolted-in base that the seat is mounted to. There was a https://rennlist.com/forums/993-forum/1027960-tillet-racing-seats-installed.html%20good%20Rennlist%20discussion about this recently including some brainy calculations on https://rennlist.com/forums/showpost.php?p=14905928&postcount=36%20how%20strong%20the%20material%20needs%20to%20be to mount that strap.
I would also go for a stronger backing plate on the chassis like https://www.torqued.io/planted-reinforcement-plate%20this%20one which I would screw with a grade 8 bolt as bolt -> spring washer -> washer -> Schroth triangular tab -> a couple washers to raise tab off floor and not put pressure on the sub strap -> chassis hole -> backing plate.
Hopefully that helps!
