Supps
Ev
 Share
It's also linked from the top of the Schedule/Results page and the drop-down menu under "Contact" - I thought it was easy enough to find but was perhaps wrong
Sincerely,
dude who put all those links on there
  • 3 months later...
Now that the supps have been located...
The rain light rule is confusing with respect to the products that are linked. Neither of the descriptions for the lights (Afterburner or Lifeline) says that the flashing feature can be turned off. But the rule says:
FIA lights and taillights must function as follows:
FIA lights must be steady ‘on’ during entire time on track.
FIA lights will not be flashing.
FIA lights must be on the exterior of the vehicle with nothing obstructing the led’s (may not be
behind glass, lenses, plastic lenses, etc.)
Taillights must be steady ‘on’ during entire time on track.
Taillights must illuminate brighter than steady on when driver is using brakes.
So, does someone know if the flashing feature can be turned off on these or whether we're just ignoring the "no flashing" rule, or we simply gave those as examples and there are others that don't flash we should look for?
Thanks for the reply, Bill.
Edit: For those that are thick like me, I believe the way to meet the rules in the supplementals is to wire the Afterburner "brake light" (which doesn't flash) as steady on, i.e. constant 12v power and NOT wired to the vehicle's brake light switch. Then don't wire power to the "rain light" at all. So, my interpretation would be to wire the Afterburner "brake light" into the vehicle's tail light circuit.
https://www.pegasusautoracing.com/pdfs/AfterburnerRainLight.pdf
Edit: Ok, so we should wire only the "brake light" (which won't flash) and it should be on all the time, i.e. not connected via the car's brake light switch AND we should use the OEM tail/brake lights?
This. ^^
Switch to brake light wire.
 Share
