National Staff Greg G. Posted April 29, 2018 National Staff Posted April 29, 2018 TECHNICAL BULLETIN 4-28-18 ST4/TT4 and ST5/TT5 Hoosier DOT Wet Tires Hoosier DOT Wet tires ST1-4 Rules 6.4.1 ST4 Tire Limitations 1) Compound Non-DOT approved tires are not permitted in ST4. DOT-approved R-compound autocross tires shall be assessed via the “Adjusted Weight/Power Ratio” in ST4. Hoosier DOT Wet tires shall be assessed as autocross tires except during officially designated "Rain Sessions" when they may be used without a Modification Factor assessment. ST1-4 Rules 6.5.2 Modification Factors Tire Type ST4 Only: DOT-approved R-comp Autocross tires = -1.0 (examples: A6, A7, DOT Wet, R1S, RS AC, Z214-C90/91) ST5 Rules 6.1.2 Tire Limitations 1) Compound 1) Tire treatments and softeners are not permitted. 2) Non-DOT approved tires are not permitted in ST5. 3) DOT-approved R-compound autocross tires (“A-tires”) are not permitted in ST5. (examples: A6, A7, DOT Wet, R1S, RS AC, Z214-C90/91) Hoosier DOT Wet tires shall be permitted ONLY during officially designated "Rain Sessions" Quote
cadmad Posted April 29, 2018 Posted April 29, 2018 under 100 tread wear would go without saying... Quote
brkntrxn Posted April 29, 2018 Posted April 29, 2018 I was wondering when someone was going to shave a set and run them. Quote
