National Staff Greg G. Posted April 29, 2018 National Staff Posted April 29, 2018 TECHNICAL BULLETIN 4-28-18 ST4/TT4 and ST5/TT5 Hoosier DOT Wet Tires ST1-4 Rules 6.4.1 ST4 Tire Limitations 1) Compound Non-DOT approved tires are not permitted in ST4. DOT-approved R-compound autocross tires shall be assessed via the “Adjusted Weight/Power Ratio” in ST4. Hoosier DOT Wet tires shall be assessed as autocross tires except during officially designated "Rain Sessions" when they may be used without a Modification Factor assessment. ST1-4 Rules 6.5.2 Modification Factors Tire Type ST4 Only: DOT-approved R-comp Autocross tires = -1.0 (examples: A6, A7, DOT Wet, R1S, RS AC, Z214-C90/91) ST5 Rules 6.1.2 Tire Limitations 1) Compound 1) Tire treatments and softeners are not permitted. 2) Non-DOT approved tires are not permitted in ST5. 3) DOT-approved R-compound autocross tires (“A-tires”) are not permitted in ST5. (examples: A6, A7, DOT Wet, R1S, RS AC, Z214-C90/91) Hoosier DOT Wet tires shall be permitted ONLY during officially designated "Rain Sessions" Quote
