joeygill Posted June 19, 2018 Share Posted June 19, 2018 I’ve had this car for 9 years, and used it solely for track days. It’s been a really fun and reliable track car, and still runs strong! Selling now because I have not been using it much at all over the last few years, priorities changed! This car is a perfect candidate if you’re looking for a fun, affordable track car, or for doing time-trials, and wheel-2-wheel racing. I built it toward the NASA Spec3 series, but changing priorities meant I never completed the build and never raced it. It would make a great car for Spec3, SpecE36, GTS2, TTD etc. There’s been a lot done to the car over the years, I’ll list the major items below but let me know if you have any specific questions. The car weighs ~2750lbs (¼ tank gas + driver). 4-door. Manual transmission. Under the Hood: Engine replaced in 2012, ~140K miles on engine (M50). Swap done by Edge Motorworks (BMW race shop out of Dublin CA) A/C and hardware removed Radiator, coolant expansion tank, thermostat, water pump and all cooling hoses replaced Spark plugs, drive belts replaced Suspension: Vogtland Spec3 springs Koni Yellow (M3 fitment) shocks all around Vorshlag camber plates Eibach anti-roll bar (front+rear) Interior: Custom-built roll protection in rear (welded-in) Sparco ProADV driver seat w/ halos VAC Motosports seat mounts Corbeau seat on passenger side 6-point G-force harnesses (both sides). FIA 2014. Momo steering wheel Sunroof delete New shifter bushings Interior is mostly stripped (sound deadening material removed) Exterior: New front wheel bearings 15x7 BMW wheels Toyo RR tires (225/50/R15) Wheel studs Cat-back exhaust (stock cats) Rear upper shock mounts reinforced Rear sub-frame reinforced + bushings replaced (by RRT in Virginia) Rear trailing arm bushings (RTAB) replaced Transmission mounts replaced Let me know if any questions. Title clean & in hand. No trades. $5400 obo - located outside Seattle WA Link to all pics: https://photos.app.goo.gl/CSURkh38HTZ3yeXs5 Craigslist ad: https://seattle.craigslist.org/est/cto/d/93-bmw-325i-e36-track-race-car/6620466539.html Quote Link to comment Share on other sites More sharing options...
TaylorGoesFast Posted April 21, 2021 Share Posted April 21, 2021 Did this ever sell? Quote Link to comment Share on other sites More sharing options...
