cjlmlml Posted July 11, 2018 Posted July 11, 2018 (edited) Professionally set up car. Use for DE, Spec Iron, comp license, or add some cams/lexan, and race in American Iron Torsen, 3.73 gears, FR ABS, GT 500 brakes, Illicit motorsports cage, very well done All Ford Racing Spec Iron parts on car except for tranny scoop. FR rear sway bar included, but not installed I will list as much as I can think of below This is from my spreadsheet when building the car - Cost was around 30k Coils Radiator Wrap Driveshaft loop ATE Brake Fluid Struts and shocks AST Adjustable Shifter MGW Miscellaneous Brake pads Labor Fuel Filter Illicit motorsports cage brake duct kit 3rd link Spark Plug auto lite Adjustable front sway bar end link kit Adjustable Back Brace Mid pipe HCU FR booster ABS Module FR Steering wheel Rear upper shock mount Strut tower brace Front lower A arm brace Bumpsteer kit Caster camber plates Front lower control arm bushings Rear upper link bushings Rear lower control arms Rear lower control arm reloc brackets Adjustable Panhard Bar Sway bar kit Tow hooks shipping tax window net strap Hood Pins Kill switch Window net Window net install kit Car Purchase Cage Transport to austin Harness seat steering quick release Hub Adapter Ford power pack w/ computer calibration (intake, muffler, oil filter, tuner) A/C Eliminator kit Brakes Brake lines lug nuts Ford racing hubs W ARP STUDS 3.73 Ring and Pinion Ring and Pinion install kit Rear differential cover Torsen Differential gear install Wheels Wheel Studs https://www.racingjunk.com/NASA-American-Iron/183072837/2005-Spec-Iron-Mustang-make-offer-must-go-.html Chris 972 822 7800 Edited September 11, 2018 by Guest Quote
SNAKBITN Posted August 16, 2018 Posted August 16, 2018 You should post this on Spec Iron FB. GLWS Quote
cjlmlml Posted September 16, 2018 Author Posted September 16, 2018 https://www.irista.com/gallery/rdpxvm0mubml Picture link, Will also post on Spec Iron FB Quote
