2003 Mitsubishi Evo 8 Lightweight
PICTURES:
https://dallasmotorsports.com/2003-Mitsubishi-Lancer-Evolution-8-SCCA-Lightweight-Wylie-TX-75098/6454227
3rd place finish at SCCA Nationals
Tuned to 600 HP
Weighs in at 2,250 pounds
The car is currently setup for F-Prepared autocross but with some minor additions it could also compete in Hillclimb, Road Race, or Drag Racing events. Heavily modified to be extremely light, fast, and reliable, the next owner will be in possession of a National Championship caliber vehicle.
To inquire about this vehicle please contact Mac Moore at 214-546-9931 or at [email protected]
Price: $38,500
Engine
1. Watts Shop 2.0L built race motor conservatively tuned to 600hp on C-16 race fuel with Pauter rods, 10:1 Arias pistons, new crankshaft, O-ringed heads, Kiggly springs/Ti retainers and much more.
2. Forced Performance 73HTA Green turbo w/84mm surge port compressor housing
3. Forced Performance FP4R cams
4. Injector Dynamics ID1000 injectors
5. Buschur Racing 65mm throttle body
6. Lightweight upper/lower intercooler pipes & ForgeRS Diverter Valve
7. Custom 52mm and 46mm turbo inlet restrictors
8. Stage 3 ported intake and exhaust manifolds
9. Coil-On-Plug Ignition system
10. 4” core Garrett intercooler and Lightweight stock intercooler as direct replacement
11. Lightweight stainless front side-exit exhaust w/14” race muffler to meet 100db limit
12. 22lb Mitsubishi Racing Ralliart Super Direct twin disk clutch
13. Lightweight racing radiator
Chassis/Brakes
14. AMS Wilwood Lightweight brake system – 4-piston front/2-piston rear brakes, stainless brake lines, Carbotech pads, extra new set of Wilwood pads
15. AST-5200 double adjustable coilovers with external reservoirs mounted inside the car
16. ShepTrans-built Stg 3 transfer case with Quaife front limited-slip differential
17. Newly rebuilt transaxle by COBB Tuning
18. Cusco 1.5-way racing rear limited-slip differential
19. Front roll center kit and steering rack bushing kit
20. Offset front control arm bushings
21. 6-pt under frame support bar
22. Titanium front strut bar
23. Fiberglass headlight covers & uninstalled custom rear fiberglass taillight covers
24. Lightweight hollow rear sway bar
25. Lightweight transmission support
26. Lightweight Mustache bar and rear differential support & solid differential bushings
27. Stainless upper & lower clutch lines
28. Polyurethane side engine mounts - cam gear and transmission
29. Custom carbon fiber trunk lid and one-off 5-lb dry carbon fiber hood
30. Carbon fiber mirrors and Mirror-finish polished aluminum roof
31. Lexan windows, including one-bolt removal driver/passenger windows
32. Lightweight front and rear doors
33. Lightened wiring harness
34. Mitsubishi Racing Ralliart rear aluminum strut bar
35. Aluminum fuel cell/fuel filters/braided line/fuel pressure regulator
36. Adjustable rear lower control arms
37. Adjustable rear toe arms
38. Custom built narrow rear trailing arms with Delrin bushings to fit deeper wheels
39. Momo steering wheel
40. Kirkey lightweight driver’s seat w/harness & Momo passenger seat with racing harnesses
41. Aluminum driveshaft
Wheels/Tires
42. Custom Bogart Racing Wheels, 15 lbs, 16x10” with Avon Racing Slicks, 11.0x23.5-16, Also include halves to convert to 16x12” wheels.
43. Two extra sets of wheels – 17x9” 6-spoke and 17x8” original Enkei's
  • 1 month later...
