covingtonja Posted August 1, 2018 Posted August 1, 2018 (edited) !!! SOLD !!! Thank you to everyone who was looking and PM'ed me, but this Car & Trailer Package has been SOLD. Racing, who I bought it from in 2016. However, due to a new role at work, I can no longer justify being away from home on weekends too. As such, I’m looking to pass this complete package on at a really great price - $10,000 = Car + Trailer + Extras!!! Car is in great shape and body is BEAUTIFUL!!! It does need to be corner balanced and an alignment, as I just replaced two two of the JRZ shocks. Safety: Custom DOM 6 point cage built with safety and stiffness in mind. Includes Foot protection bars for driver and passenger (If passenger seat added for track days). Cage tucked in very close to provide maximum driver space (I’m 6’ 3” and 290 lbs and fit well!) OMP Seat HTE-R XL seat Seat bracket integrated to the cage not the floor Floor plates on all 6 points vertical and horizontal 6 point harness Window net Center net Fire suppression system Engine: Rebuilt E36 M3 engine S52 (3.2 liters USA E36 M3) w/ new rod bearings and bolts Euro E36 M3 Dual Pick-Up Oil Pan Bimmerwold 3 inch stainless steel exhaust Bimmerworld Race Air Intake box w/ new filter Bimmerworld dual pump fuel starvation kit Custom EPIC tune by Previous Owner. Mishimoto Radiator Stuart high flow water pump Silicone radiator hoses Silicone intake hose Motorsport Thermostat Aluminum Thermostat housing Timing chain tensioner New crank sensor New cam sensor Custom self-bleeding Euro Coolant setup Machined head w/ valve job, resurfaced All new seals Rebuilt injectors Custom stainless steel lines and oil cooler Fuel pressure regulator Mass air flow sensor Knock sensors Suspension, Wheels, Tires & Brakes: JRZ RS double adjustable internal race coiler suspension Front brake cooling, ducts, hoses and backing plates Tires: 6 New Hankook Z214 – 245/40R17 8 Used Hankook Z214 – 245/40R17 (4 on Car) 4 Hoosier Rain Tires (Older) Wheels: 12 Kosei K1 Racing Wheels – 17” x 8.5” (4 on Car) Brake Pads New in the Box: PFC 11 Front & Rear GLOC 12 Front & 18 Rear New Wheel Studs Reinforced subframe Power flex race subframe, trailing arm and diff bushings Ground Control adjustable rear lower control arms Stainless steel braided brake lines Delron front control arm bushing Ground control race spherical camber plates Rear height adjusters Transmission: JB racing flywheel w/ Clutch Masters clutch kit Diffsonline custom race differential – 3:64 ratio - 3 clutches and ramps Stainless steel braided clutch flex line BW clutch stop Short shifter Jafster shift knob DSSR shifter linkage Resealed ZF transmission Red Line synthetic fluids Interior & Driver RacePak race dash with GPS lap times, best possible time etc., Integrated with temp and pressure (oil and coolant), Shift lights, RPM, Speed etc. Custom carbon dash fill pieces Custom switch panel wired for cool shirt, helmet blower and more Sparco race steering wheel, hub and quick release Race pedal covers Dead pedal Kill switch Longacre rear view mirror Miscellaneous: Set of Race Ramps (45”L x 14”W x 6”H) Cleaned and trimmed wiring harness with all extra wiring removed and cleaned M3 bumper Custom BMW Roundel Colored paint job Trailer: 2016 Big Tex 70DM-20BK – 20’ Double Axle Car Hauler https://www.bigtextrailers.com/70dm-tandem-axle-diamond-back-car-hauler GVWR: 7000 lbs. 2-3500# Axles w/2 Brakes, 32" Dovetail 5' Slide in Rear Ramps Front Stop Rail 1/8" Diamond Plate Floor 4- D rings recessed Chrome Wheels Spare Tire Included Fold Back/Wrap Tongue 2,000# Fold-Up Jack EZ Lube Hubs Dexter Brand Axles Nev-R-Adjust Electric Brakes Removable Tear Drop Style Fenders Sealed Lighting L.E.D. Lighting Package Complete Break-A-Way System w/Charger Edited August 20, 2018 by Guest Quote
DMCNCAL Posted August 5, 2018 Posted August 5, 2018 Hello, I'm interested in your car but had a few questions. - Can you tell me the year of the car? Is the car and M3 sedan or a conversion? - Year of the motor? Rebuilt to stock specs? Any mods? Hours/miles since rebuild? - Original Transmission? - Dyno info? - Did you race the car? - any other info on the car Thanks Doug Quote
Tykrane30 Posted August 14, 2018 Posted August 14, 2018 (edited) My apologies for the double post Edited August 15, 2018 by Guest Quote
freeskier173 Posted August 14, 2018 Posted August 14, 2018 Hey Jason, Very interested in the package deal. Would be great to learn a little more of the cars history. Let me know if you can talk one evening or I can email over some more questions. Looking forward to hearing more on the car if still for sale! Cole Quote
