1997 BMW M3 Coupe
Black M3 coupe, 5 speed, 167k miles. Clean title, no accident history.
Prep'd for HPDE track events. The interior behind the rear seats has been removed, but the car still has AC, power steering, front interior etc.
Misc:
Dinan intake
Dinan Stage II software
Carbon fiber sunroof plug
Continental Extreme Contact DW tires/ oem M3 contour wheels 225/45-17 front and 245/45-17 rear (fairly fresh, ~2 track days, 2k street miles)
MassiveBrakes seat mounts
Corbeau FX1 seat (driver's)
Fog light block off plugs
Recent:
OEM rear shocks
Rogue Engineering rear shock mounts and reinforcement plates
OEM power steering lines and reservoir
spark plugs
brake fluid flush (motul 600)
tie rods and 4 wheel alignment
front lower control arms with ball joints
LCA bushings
swaybar bushings and endlinks
depot headlights (glass)
depot corner markers (glass)
Redline tranny fluid
hood struts
hood cable
OEM front shocks
OEM upper strut mounts front
Brake rotors front/rear
Brake pads (Hawk DTC60) front/rear
Previous owners:
window regulators
injectors
cooling system overhaul (including hoses, radiator, water pump, thermostat, thermostat housing)
clutch and presssure plate
valve cover gasket
vacuum lines
fuel filter
throttle position sensor
Compression tested when spark plugs were replaced:
#1: 210psi
#2: 202psi
#3: 202psi
#4: 205psi
#5: 205psi
#6: 205psi
Needs:
1) Basic exhaust work (rear O2 sensor etc)
2) Wheel speed sensor (traction control and ABS lights are on)
Runs and drives extremely well. Very reliable, can be driven anywhere. I still have the rear seats and interior, and will be happy to include them with the car if anyone prefers to reinstall them.
I'm located in Charlotte, NC. Asking $6,999
