rcrescencio 0 Posted September 21, 2018 Share Posted September 21, 2018 1. The proposed addition or change. Simplify how average HP is calculated. 2. The reason behind the proposal. The website (laptop and/or mobile devide) don't always show the correct/consistent numbers. The formula isn't transparent and makes it more complicated/difficult than it needs to be. I'm all for average HP, but GTS is way too complicated and lack transparency in its algorithm. ST average HP rules, for example, uses this formulaAvg HP = [Max HP +(sum of the seven highest data points)]/ 8. The number of points can be modified, but there isn't any magic behind trying to get the "area" under the curve for an average HP. 3. Any documentation supporting the request. At Nationals, my input values on the phone did not match laptop values. After a dyno compliance run, the Series director showed me my new calculated minimum weight, only to come back 1 hour later with different values because all of the sudden the calculator showed him different results. With a simple arithmetic, there wouldn't be any surprises on either side (officials and participants). 4. Proposals to be submitted and signed by GTS members to be considered. (indicate Class and Region, please). Applicable to all classes Roberto Crescencio GTS3 - Mid Atlantic Link to post Share on other sites
focusedintntions 1 Posted September 24, 2018 Share Posted September 24, 2018 so maybe rather than change the way the avg is calculated, just publish the formula? Link to post Share on other sites
rcrescencio 0 Posted September 24, 2018 Author Share Posted September 24, 2018 That's a step in the right direction, but i suspect the formula is more complex than just 8 numbers divided by 8. so maybe rather than change the way the avg is calculated, just publish the formula? Link to post Share on other sites
Ev 0 Posted September 24, 2018 Share Posted September 24, 2018 so maybe rather than change the way the avg is calculated, just publish the formula? Agreed, any 6th grader could do it in Excel if they need some assistance. Link to post Share on other sites
jvanhouten 0 Posted September 25, 2018 Share Posted September 25, 2018 +1 to publishing the formula. Link to post Share on other sites
rokkit 1 Posted September 26, 2018 Share Posted September 26, 2018 I think the current system is working great. Link to post Share on other sites
Mike Miller 0 Posted September 27, 2018 Share Posted September 27, 2018 I have no problems with the current system. Link to post Share on other sites
daytonars4 4 Posted September 27, 2018 Share Posted September 27, 2018 I am fine with the current calculation as long as you figure out a way to may it produce consistent results. Otherwise will need to simplify the process. Lawrence Gibson GTS2/3 Midatlantic Link to post Share on other sites
