MiniNL Posted September 24, 2018 Share Posted September 24, 2018 Have 1 new set and multiple used sets of Yokohama Advan A052 tires in sizes 265/35R18 and 295/35R18. Used ones have less than 50 miles on them. Will split up in fronts and in rears. Tires are in SLC, but can meet anywhere between there and Heber City. $350 per used pair, $560 per new pair. Info from Tirerack: The ADVAN A052 is Yokohama's Streetable Track & Competition racing tire developed for drivers who participate in high-performance driving schools, open track events and circuit-type club racing. The ADVAN A052 is designed to offer Yokohama's highest level of DOT-approved performance to the most demanding enthusiasts. The ADVAN A052 molds Yokohama's motorsports MS Compound into a track-ready, asymmetric tread design for extreme levels of grip. The low-void tread pattern features wide center ribs and an expansive outboard shoulder for maximum traction, and the rounded tread profile helps to evenly distribute pressure across the footprint, creating more contact with the road. Notches in the outboard micro groove improve cooling for added durability and consistency when used on the track. Two wide, circumferential grooves and the notched inboard shoulder improve hydroplaning resistance, but care should still be taken when standing water is present. A casing consisting of two plies of nylon cord supports two wide, steel belts beneath the tread and helps contribute to precise and responsive handling. Two spirally wound, nylon reinforcement plies improve high-speed durability and further promote the steering response expected from a track-ready tire. Warning: ADVAN A052 radials meet DOT requirements, however they are not recommended for driving in wet conditions where standing water is present and there is the risk of hydroplaning; drivers should drive cautiously at reduced speeds if they encounter these conditions. This is especially true of shaved or worn tires. And like other Streetable Track & Competition tires, these tires are not intended to be stored, serviced nor driven in near- or below freezing temperatures, through snow or on ice. 295/35-18 295/35/18 265/35/18 265/35-18 Quote Link to comment Share on other sites More sharing options...
