1990 Honda CRX B16 NASA PT HC2 SCCA STL (NASA Champs Winner)
1990 Honda CRX
B16 Swap With TypeR LSD Trans
Built for HC2 or STL
Drivetrain:
B16A1 block, crank, and pistons
PR3 head and intake (not port matched)
Head shaved .015” for 10.75:1 compression ratio
Honda standard head gasket
ARP head studs (installed) and main studs
Integra Type R cams (stock cams included)
Skunk 2 springs and titanium keepers
Skunk 2 cam gears
New valve seals
Rywire harness with single firewall disconnect
Socketed ECU
Hasport mounts and cable to hydro conversion
96 Type R S80 transmission with helical lsd (shortest factory gearing available)
Exedy flywheel HF01
Exedy clutch 08800B
Synchrotech carbonfiber synchros
Suspension:
Whitener Racing Shocks
Speedway Style Rear Bar
ST Front Sway Bar
ES Bushings
Recent ball joints, wheel bearings, and tie rods
Brakes/Wheel/Tires:
Fastbrakes 11.75 front brakes (fits under some 15x7s)
Aluminum Insight rear drums
Wilwood prop valve inside cabin
15x9 front 15x8 rear 949 6UL wheels
BFG Rival-S tires with lots of tread
The car won a NASA TTF championship in 2015 along with a 3rd place finish in PTE that year (and that was still running the restricted PTF power level). It took second place in TTF at Laguna Seca in 2016. The car has at least a dozen NASA class lap records.
The car is in good condition. Has never had any major wreck damage. There is a well built 8 point cage with NASA logbook. I think the window net is out of date but it should be race ready with new fluids. I have a good number of extra body parts including two rear hatches (one glass, one lexan). I also have a spare parts box that has spare control arms, complete loaded front knuckles with new bearings and new wheel bearings for the rear. I also have a complete wiring harness to super easily swap the car back to a D series motor. The extra parts can be included or sold separately.
$7000
Located in Fort Worth, Texas
Delivery available
Pics:
https://photos.app.goo.gl/f6jfVvJWezaKPqyw8
That photo album has years of photos including the car in it's construction and crash damage.
Forgot to mention that the wrap will be removed before sale.
  • 3 weeks later...
