Vettedoctor Posted November 16, 2018 Share Posted November 16, 2018 Up for sale is a 2002 Corvette Z06 Championship winning ST2/TT2 car (46,000 original miles) Some assembly required Includes the following: NASA/SCCA legal roll cage Pfadt spherical bearing A-arm bushings LG drop spindles Pfadt HD adjustable front and rear sway bars SKF race bearings w/extended ARP studs Pfadt coil-overs w/custom rate springs StopTech ST60 380x35 front brake kit Custom StopTech ST40 rear brake kit (larger 34/28 mm pistons) LG pinion driven trans / diff pump - coolers mounted behind rear brake ducts RPM level V transmission w/custom 5th & 6th gears MN6 1-4 ratios & M12 5&6 ratios DTE level 5 differential w/Quaife center section DTE Trans/diff brace RPS Billet twin clutch & aluminum flywheel – 25 lbs complete ACP rear wing – 2 sets of wing mounts – 1 set roof height – 1 set 8” above roof height Mallet air extractor hood w/ carbon fiber wheel well vents – pinned Custom side skirts w/side seals Battery relocated to trunk – jump posts installed on passengers’ side door bar – kill switch on drivers’ side Kirkey seat – Window net and RH side net – panoramic rearview mirror and low profile side mirrors HVAC removed and blocked off – defrost blower fan Halon fire system Racepack G2X data system Kooks 1 7/8” to 2” stepped headers – ceramic coated –3” X pipe and custom rear/side exhaust CCW Corsair C14 18”x11” 1-piece front wheels – CCW Classic 18x12” 3-piece rear wheels Blackdog Racing carbon fiber front fascia Blackdog Racing carbon fiber undertrays – 1 standard length – 1 custom extended 4“ This car was designed and optimized for NASA ST/TT competition and weighs 2,960 lbs dry – no fuel, no driver – with Hoosier 315/345 tire combo. Frame is strait - no damage Roller with all parts listed above - $17,900 Included in that price are spare body parts including LF and RF inner fenders, LF fender, driver and passenger doors, and roof panel w/rear window. Optional extras and available engine packages include: Racelogic Video VBOX lite video/data system w/predictive lap timing OLED display and Micro Input Module - $1,300 DRM built LS6 heads and cam – made ~400+ rwhp/tq - $5,000 Goodwin built - LS7 w/ported LS3 heads makes 515 rwhp /515 rwtq 3 stage ARE dry sump – designed for NASA ST/TT 6” C6 Z06 style dry sump tank mounted in stock battery location - $12,000 In 2012 this car won the 2012 NASA TTS National Championship at Mid-Ohio as well as runner up in the ST2 National Championship race. It also won the STR2 National Championship before being DQ’d for a questionable passing under caution infraction. In 2013 he was runner up in TT2 at NASA Nationals by less than .200 of a second This car/package has set numerous track records - still being held today: TTS: Mid-Ohio: 1.30.2 Road America: 2.22.70 Brainerd: 1.41.5 Miller Motorsports Park: 2.02.4 TT2: Putnam Park: 1.12.7 Autobahn South: 1.28.7 Gingerman: 1.33.6 ST2: Putnam Park: 1.14.6 Blackhawk Farms: 1.15.1 Gingerman (Short): 1.30.1 Autobahn South: 1.29.5 Brainerd: 1.44.0 For any question or more information call or email Joel at Corvette Sports (920) 467-2833 – email: [email protected] More pictures available at: https://photos.app.goo.gl/rqS86HSqedT1Suc8A Car is located in Sheboygan Falls, WI Quote Link to comment Share on other sites More sharing options...
Vettedoctor Posted January 29, 2019 Author Share Posted January 29, 2019 (edited) Sold! Edited February 6, 2019 by Vettedoctor Quote Link to comment Share on other sites More sharing options...
