salemate Posted November 22, 2018 Posted November 22, 2018 Read below for Price options. Offering running or roller as some like to install different types of engine configurations in these cars. Yellow car... PWC - GTS spec race car built to high standard. Good quality hard fab, parts, engineering and aero.1:25 - CTMP1:09 - GP3RChassis:• 2014 Scion FR-S new• Extremely well built roll cage• Gusseted and extended to strut towers• Lightweight• Strengthened strut tower platesInterior:• OMP containment seat with HANS• OMP 6point harness• Electric firebottle system• Sparco steering wheel with 4 switch tabs, quick release hub• Fuel Safe fuel cell, custom. recertified 2018- lexan windows- red head dry break fuel fill and discriminator valveBrakes:• Tilton 600 series floor mount 3 pedal assembly• brake-o-meter balance bar adjuster• ABS• Stoptech 6 pot calipers, floating AP discs w/ aluminum hats• Carbotech, Hawk pads• Stoptech 4 pot calipers, floating AP discs w/ aluminum hatsSuspension:• 4 way adjustable coil-overs JRI custom valved• Large range of spring rates• SPL parts, RacerX arms all on heim joints, fully adjustable• Eibach and Hotchkis sway barsEngine: 500HP• 4 stage (pressure stage) Dailey Dry Sump EJ25 with Garret turbo • Freshly built by Gord Busch Performance, also have IAG Stage 3 motor• light weight AN Line and fittings, Radium tank• Setrab oil cooler• Fluidyne custom spec radiator• Large intercooler and 4” cold pipingElectronics:• Custom MOTEC ECU and data logger/ dash AiM capable• Custom wire loom• deutch and Bosch connectors - EVERYTHING LABELLED!Driveline:• Carbon fibre driveshaft and 600hp rated axle shafts• MagnumXL 6sp gearbox with custom gearing• CUSCO 1.5 way differential with optional gears• CUSCO large capacity and cooling diff plateWheels:• Volk TE37 18”x9”• FAST FC04 18"x10" and set of 18"x9"AERO: Hartman Aero 14"x72" rear wing, custom carbon splitterSpares:Included but not limited to:• Shocks• Brake rotors and pads (new)• Engine parts• Pumps• Wiring• Gear sets• Misc parts PRICE: $40,000 Roller - $56,000 with engine and transmission Black car: CTCC or GT extremely well built, great handling race car.FRS – spec sheetChassis:• 2013 Scion FR-S• Extremely well built roll cage• Gusseted and extended to strut towers• Lightweight• Strengthened strut tower platesInterior:• Recaro containment seat with HANS• Schroth 6point harness• Electric firebottle system• Sparco steering wheel• ATL fuel cellBrakes:• Tilton 600 series floor mount 3 pedal assembly• Tilton balance bar adjuster• Tilton proportioning valve in car adjustable• AP 4 pot calipers, slotted rotors• Carbotech, Ferodo pads• STI rear calipers, DBA rotors rearSuspension:• 3 way adjustable coil-overs (STD Suspensions)• Large range of spring rates• SPL parts• Eibach and Whiteline sway barsEngine: 335HP• FA20 – Turbo• Freshly built by Lachute Performance (less than 2 hours) running time• Reduced compression – race pistons and rods, arp fasteners and head studs• Baffled oil pan• Garret turbo• 325 wheel horse power, 300lbft torque• Mishimoto sandwich plate• Setrab oil cooler• Fluidyne custom spec radiator• Large intercooler and 4” cold pipingElectronics:• Arc model 8000 flat touch switch panel• ECuTek comes with dongle and licence• AiM MXL Pista data logger and dashDriveline:• Lightweight driveshaft• Stock gearbox• Tomei 1.5 way differential with taller gear• CUSCO large capacity and cooling diff plateWheels:• Comes with 17”x9” Enkei RPF1 black wheels • 10 wheels• Some pictures are shown with Volk TE37 18”x9” not included but can be purchased separately (10) wheelsSpares:Included but not limited to:• Shocks• Brake rotors and pads (new)• Engine parts• Pumps• Wiring• Gear sets• Misc parts PRICE: $30,000 Roller or $35,000 with engine and transmission Quote
