M1cheleAbbate Posted December 24, 2018 Posted December 24, 2018 More info at: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F323611792331 GrrRacing is selling their SCCA multi-championship winning supercharged 2013 Scion FR-S driven by Michele Abbate (former professional driver for Scion Racing). This FRS is race prepped and turn key ready for the SCCA STU class. It is supercharged per the class rules with the Edelbrock E-Force direct fit Supercharger. It has always been tuned by Delicious Tuning in Carlsbad, CA. No expenses were spared on this build and it has been proven to be one of the fastest FRS chassis on the west coast. It was last ran at Buttonwillow Raceway with SCCA/Cal Club where it set a new track record in addition to the race win in Sept of 2018. We have developed and race this car since 2014. We have a full log book and report of the modifications and upkeep on the car that we would be willing to share with the buyer. Below is a list of the current components on the race car, totaling well over $55,000 in modifications alone. The car is currently located in Las Vegas, NV. See more about the team, driver, and car at: www.GRRRacing.com or www.M1cheleAbbate.com Current Modifications: Engine Accessories Edelbrock E-Force Supercharger Radium engineering fuel rails Deatschwerks 700cc injectors Mishimoto oil catch can Mishimoto radiator and hoses Mishimoto oil coolers x2 Mishimoto oil magnetic drain plug Davies Craig electric water pump Antigravity Battery Spal fans x2 CSG Radiator Shroud Nameless Performance Lightweight ECU Bracket Nameless Performance Rally Exhaust (lightweight single exit exhaust)Fuel System Delicious Tuning flex fuel kit Fuel Safe 15 gallon cell w/ new rear set FCST (installed in 2017) Fuel safe window mount dry brake Radium engineering FCST Aeromotive fuel pressure regulatorDrivetrain Cusco LSD diff Cusco diff gears 4.55 Rear End Gear Driveshaft Shop 600hp axles ACT Unsprung 6 Puck Race Clutch ACT Lightweight Aluminum FlywheelBrakes Beastronix Nanny controller Radium Engineering booster brace Wilwood front calipers & pads Wilwood front rotors APR carbon brake ducts Wilwood brakes fluid Stainless lines DBA rear rotors Porterfield rear padsWheels and tires WedsSport Wheels TC105N Hoosier A7 225/45/17 (1 heat cycle)Suspension Pedders coilovers with remote reservoirs Cusco Front lower control arms Whiteline Front and Rear Sway bar Whiteline Front and Rear Endlinks Whiteline Rear brace Whiteline Anti-dive/caster Correction Kit Whiteline Roll Center Bump Steer Kit Whiteline Rack and Pinion Bushing Whiteline Rear Camber Correction Bushing Whiteline Rear Control Arm Bushings Camber Correction Kit Whiteline Rear Crossmember Bushings Whiteline Gearbox Bushing GTSPEC Rear Adjustable Camber Arms GTSPEC Rear Subframe CNC Reinforcement Panels GTSPEC Rear Trailing Arms GTSPEC Rear Lower Subframe Reinforced Tie Brace GTSPEC Rear Lower T Brace GTSPEC Rear Adjustable Toe Arms GTSPEC Front 4 Point Subframe Reinforcement Tie Brace GTSPEC Front 4 Point Ladder Brace ARP Wheel Studs Muteki Extended Lug NutsInterior Urban Metal Works Custom SCCA Legal Roll Cage with NASCAR door bars Autometer Oil Temperature Pro Elite Gauge Autometer Water Temperature Pro Elite Gauge Autometer Air Fuel Ratio Wideband Pro Elite Gauge Autometer Fuel Level Pro Elite Gauge Autometer Boost Pro Elite Gauge Autometer Oil Pressure Pro Elite Gauge Autometer Fuel Pressure Pro Elite Gauge Recaro Pro Racer HANS Seat with Head Bolster TAKATA Race 6 Hans Harness Driven Steering Wheel NRG Steering Wheel Short Hub NRG Gen 2.5 Steering Wheel Quick Release Kit DTA/Rogue Status Shift Knob Custom Altered Race Dash with Carbon Fiber Gauge Bezel Schroth window net Ultra chiller driver cool system Scosche Magic mounts Painless Master Shut Off Kill Switch Fire Extinguisher with Scosche Quick Release Mount Exterior Seibon Carbon hood with custom Marsh Power House Reverse Cowl Vent (STU Spec) Seibon wet carbon trunk Five Axis Design FR-S Aero Kit (Side Skirts, and spare front bumper with lip and APR Splitter) APR Performance Splitter APR Performance GTC-200 spec wing with custom STU spec 2.5” risers APR Performance Splitter Support Rods APR Performance FR-S Brake Duct Kit Pegasus Auto Racing Quick Release Adjustable Body Hold Down Latches TAKATA Front and Rear Tow Straps Cusco Rear Lexan Window Marsh powerhouse fab carbon Windows Custom 3M wrap by Reklaw Design Winjet headlights Winjet tail lights Quote
