rocketman Posted April 1, 2003 Posted April 1, 2003 I'm looking into a long-term replacement for my old T5, read in the rules where any synchronized tranmissions are legal, so my question is twofold: What is being used by most participants? Tremec, T5, T56, etc? Is 6 speed legal? Thanks for any help. Quote
Adam Ginsberg Posted April 1, 2003 Posted April 1, 2003 Old saying....."RTFM". NASA 2003 AI Rules, section 7.9: Drivetrain 7.9.2 AI cars must use synchromesh-type transmissions. Non-synchro transmissions such as Jericos are not allowed in AI. Looks like a T56 is ok, as well as a TKO. Quote
rocketman Posted April 1, 2003 Author Posted April 1, 2003 Wow, another RTFM. Sorry for the stupid question, thank you. Quote
Adam Ginsberg Posted April 2, 2003 Posted April 2, 2003 Damn....don't take it so seriously Mike. It was a joke - no offense meant. It wasn't a stupid question at all. I need to brush up on my 'net etiqutte - I think I've picked up too much cc.com-esque. Quote
Guest Posted April 2, 2003 Posted April 2, 2003 No worries, I thought I'd done something to get in hot water. Those rules are something I read over and over when we first built the car and I still missed plenty. Quote
OldCMC17 Posted April 2, 2003 Posted April 2, 2003 So, let me ask this then. Would someone be better off with a T56 or TKO? I'm just wondering about the tracks and which gears are going to be used more often. I know at TWS a larger 5th gear is needed to pull down the straight, but don't know if a 6th gear would ever be used. I don't know the weights of the T-5 vs. TKO vs. T56 either. I would think that matching the best gearing overall would be a key consideration to maximize powerband of the motor coming out of the corners. I might be way off base here..but just thinking outloud. Quote
OldCMC17 Posted April 2, 2003 Posted April 2, 2003 Damn....don't take it so seriously Mike. It was a joke - no offense meant. It wasn't a stupid question at all. I need to brush up on my 'net etiqutte - I think I've picked up too much cc.com-esque. Remind me not to breach protocol around you Adam. CC has done corrupted you. Quote
Guest Posted April 6, 2003 Posted April 6, 2003 Don't you guys worry...we'll keep Adam "Saddam" Ginsberg in line down here in Texas!!! Quote
Adam Ginsberg Posted April 7, 2003 Posted April 7, 2003 Damn....bust a fellow racer's chops, and you start calling me "Saddam". No worries - the only gas I'll be using is 93 octane. Mike - how is it your post showed up as Guest? Quote
Members Al F. Posted April 7, 2003 Members Posted April 7, 2003 Just thought I'd put in my 2 cents since we've recently run at Fontana, which I believe is about as fast as CMC cars will go. Running at about 150mph, I think you're more limited by horsepower than by running out of gear. I have a 4th gen Camaro, and never used 6th at Fontana. In fifth, I would hit about five grand going into turn 1, but the rpms had basically stopped rising. I have 3.42 rears. Hope the info helps. Quote
racercosmo1548534707 Posted April 7, 2003 Posted April 7, 2003 So, let me ask this then. Would someone be better off with a T56 or TKO? I'm just wondering about the tracks and which gears are going to be used more often. I know at TWS a larger 5th gear is needed to pull down the straight, but don't know if a 6th gear would ever be used. I don't know the weights of the T-5 vs. TKO vs. T56 either. I would think that matching the best gearing overall would be a key consideration to maximize powerband of the motor coming out of the corners. I might be way off base here..but just thinking outloud. A TKO 2 is a better choice. You will never use 6th gear in a CMC car. At Fontana, our AIX car had plenty of legs with 3.89 gears and the .83 5th. http://www.ttcautomotive.com/English/products/tremec.asp Quote
rocketman Posted April 7, 2003 Author Posted April 7, 2003 Adam, I'm not sure why I showed up as guest in the first post in this thread, up above it shows "Log out [ Admiral ] so I thought I was logged in, but the second guest post is not mine. I don't use names like "Saddam" in jest. Quote
