Engine Mounts
It sounds fairly clear here:
8.13.2. Engine mounts must remain OEM stock or OEM equivalent specifications
but just to be sure, are poly engine mounts not allowed? [oem type] rubber material only?
Poly engine mounts for an LT1 actually cost less than the equivalent rubber replacements!
  • Members
I guess that all depends on where you shop eh?
This is a good point, thanks for bringing it up and thanks for asking in advance. Poly motor mounts are ok since all they do is increase the stiffness of the mount and the cost is comparable for all cars. We just want to make sure people don't relocate the motor.
