Guest Posted January 17, 2005 Share Posted January 17, 2005 Can someone post some front window pics of the window clips or email them to me? Ford or GM will work, I can't see there being much of a difference. [email protected] Also, where can these be found? Searched the internet with little success. Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
GT4Point6 Posted January 17, 2005 Share Posted January 17, 2005 I didn't log in before posting the above post. Guest should read GT4Point6. Thanks, Quote Link to comment Share on other sites More sharing options...
Adam Ginsberg Posted January 18, 2005 Share Posted January 18, 2005 Kevin - the clips on my car were made from bar stock AL by the previous owner. Cut and bent for each location ( as well as rear window straps ), then pop riveted into place. I don't have any close up pics of them installed, unfortunately. They were removed to install a new windshield ( can you say HOOD PINS! ), and haven't found their way back onto the car. If you're interested, I can take a few pics of just the clips themselves, and post 'em up. Quote Link to comment Share on other sites More sharing options...
Tony G Posted January 18, 2005 Share Posted January 18, 2005 Easy way is to just buy a stick of aluminum around 3/4 to 1" wide ,and cut 5 pieces 3" long. Put three on the top of the windshield and one on each side of the lower area windshield. Just rivet in place. Tony Guaglione Quote Link to comment Share on other sites More sharing options...
rzaron53 Posted February 28, 2005 Share Posted February 28, 2005 What are the other two dimension of the window clips? ? x ? x 1" ?? Quote Link to comment Share on other sites More sharing options...
rzaron53 Posted February 28, 2005 Share Posted February 28, 2005 Opps, I meant the other one dimension..... 3" x 1" x ? Quote Link to comment Share on other sites More sharing options...
King Matt1548534716 Posted February 28, 2005 Share Posted February 28, 2005 You're looking for 1 inch wide by 1/8-inch thick aluminum strap to cut into shorter sections. Quote Link to comment Share on other sites More sharing options...
Adam Ginsberg Posted February 28, 2005 Share Posted February 28, 2005 Also, it would be a good idea to wrap/cover/protect the ends that touch the windshield or back window. Not doing so could cause it to dig into the glass, or possibly break it. Quote Link to comment Share on other sites More sharing options...
GT4Point6 Posted March 1, 2005 Share Posted March 1, 2005 HD sells 3/4", 1" and 1.5" x 1/8" thick bars in 3' and 4' lengths for about $5. Quote Link to comment Share on other sites More sharing options...
rzaron53 Posted March 7, 2005 Share Posted March 7, 2005 Ok, after 30 min wandering around HD I found the material, cut it, deburred it, ect. I drilled a single pilot for the pop rivet, but then I thought there may be a requirement for the no. of fasteners. Is there a requirement? I would rather drill 5 holes through my car than 10. Thanks. Quote Link to comment Share on other sites More sharing options...
Tony G Posted March 7, 2005 Share Posted March 7, 2005 I would say two holes per clip,because if there is only one hole you could have the clip turn on you which would make it worthless,and with two that could never happen. Tony Quote Link to comment Share on other sites More sharing options...
King Matt1548534716 Posted March 8, 2005 Share Posted March 8, 2005 I used 2 holes per clip in mine, and I would recommend attaching them with sheetmetal screws rather than rivets just in case you ever have to remove them. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 8, 2005 Share Posted March 8, 2005 please use rivets ( they can be drilled out to remove) as sheet metal screws have been known to end up on track and will ruin a good TOYO . yours or someone else .quin sabe ? # 6 cmc Quote Link to comment Share on other sites More sharing options...
Tony G Posted March 8, 2005 Share Posted March 8, 2005 Agreed,use rivets...two of them Tony Quote Link to comment Share on other sites More sharing options...
