tomlinmgt Posted February 19, 2005 Share Posted February 19, 2005 From the CMC rules: 8.23.2. Any fuel lines/hoses that pass through the passenger compartment must be metal or metal braided From the NASA CCR: 15.4 There must be a solid metal bulkhead completely seperating the fuel cell, fuel tank, filler neck hoses and/or vent lines, from the driver compartment. I have an FIA-approved ATL fuel cell that will be enclosed in an aluminum box (acting as the bulkhead) mounted in my CMC Capri. I need some clarification with regard to the routing of the vent line. The fuel line passes out of the side of the box and makes a short run through the interior (passenger) compartment before it passes through the floor at a pass. side rearward location in the vehicle. It is of braided steel construction. I see that this is legal according the the CMC rules. My vent line passes out of the back of the box and connects to a bulkhead fitting at the rear sheet metal where the license plate would mount, completely sealing it from the interior compartment. It is also of braided steel construction. There is about a six-inch run of hose from the aluminum box to the bulkhead fitting. The CCR says no vent line in the driver compartment. The CMC rules say you can have a fuel line passing through the passenger compartment. Am I going to be illegal if my braided steel vent line passes outside of the bulkhead and makes a six-inch run through the interior compartment (at the most rearward location possible)? Is there only a concern if the vent line is of other than metal braided construction and/or does not have its vent point outside of the passenger compartment? This is the set-up the car came with and was A-Sedan legal before I obtained it. Thanks, Michael Tomlin Quote Link to comment Share on other sites More sharing options...
Members Al F. Posted February 20, 2005 Members Share Posted February 20, 2005 Your setup is legal. Vents have to be outside the driver's compartment. All lines that run through driver's compartment must be braided and secured properly. You're all set. Quote Link to comment Share on other sites More sharing options...
