Toyo Tire Pressures, anyone?
Keith
Yeah, I was fishing because this was the BIG SECRET in AI... It appears that I will need to be slightly higher than the optimal 35 hot since these tires are higher profile than the AI 275/40R17's. That's what I expected.
Kent, I will probably get a chance to call you tomorrow sometime.
Keith,
I'm sure there is some variances between cars so a little experimentation is needed. My car likes to come off the track at 36 PSI. If I get too far above that the car gets loose.
Starting pressure is temperature dependent anywhere from 30 in the winter months to 24 when its around a 100. I typically start with a pound or two more in the rear.
Mike
