GT4Point6 Posted June 21, 2005 Share Posted June 21, 2005 I have the Lakewood driveshaft safety loop as does Brett I believe and we are both running the FMS aluminum ds. I had the counter weight making contact with one of the mounting bolts at WSIR on the exit of turn 4 and I took the bolt out that was interfering as a temp fix and it stopped. Brett had the same banging at BW but has a much better solution. He had the loop welded up and remove the bolts which I will be doing this week. Quote Link to comment Share on other sites More sharing options...
