mcmmotorsports1548534724 Posted February 20, 2007 Share Posted February 20, 2007 How many of you guys are running the Canton Oil Pan? Quote Link to comment Share on other sites More sharing options...
jeffburch Posted February 20, 2007 Share Posted February 20, 2007 I'll go out on a limb to say that more do than don't. jb Quote Link to comment Share on other sites More sharing options...
Tony G Posted February 20, 2007 Share Posted February 20, 2007 On the West Coast I would say maybe 3-4 have one out of 35 of us. I personally do not have one and never have needed one, but that is just me. I use an accusump set up. Tony Guaglione Quote Link to comment Share on other sites More sharing options...
Lady in Nomex Posted February 20, 2007 Share Posted February 20, 2007 Canton Accusumps are popular as an alternative to their pan. The Canton Accusump is superior to the Moroso product BTW - I have had both. Quote Link to comment Share on other sites More sharing options...
mcmmotorsports1548534724 Posted February 21, 2007 Author Share Posted February 21, 2007 Thanks guys for your input. Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 21, 2007 Share Posted February 21, 2007 so do you guys need the accusump cause you dont have the pan - possibly? i like having the pan cause it helps in keeping the pick-up covered. instead of having the uncovered pick-up helped out by a pressurized tank full of oil. its also lighter than an accusump. you dont have to find a place to mount a pan, it kinda only goes in one place. i wont have a line fail w/ a pan. and now the rules have changed to allow both, but i dont think i'll add the accusump. just my .02. Quote Link to comment Share on other sites More sharing options...
GT4Point6 Posted February 21, 2007 Share Posted February 21, 2007 I run an accusump, modular 4.6. Didn't do the oil pan since the past rules only allowed one or the other. Mod motor has to be removed (or k-member dropped) to install a Canton so I went the easy route. I have a low oil pressure light set to 30 psi (modulars like pressure) and it's only flickered a couple of times before the accusump at the entrance to turn 4 at Infineon (downhill braking, right turn). Haven't seen it after the accusump install. If I ever pull the motor, I think it's worth the extra capacity if nothing else as I'd like to think they work as designed. Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 21, 2007 Share Posted February 21, 2007 fair enough. thanks. Quote Link to comment Share on other sites More sharing options...
Members Al F. Posted February 22, 2007 Members Share Posted February 22, 2007 I'd think the easy of install probably affects a lot of people's decision as to one or another. I put a Canton in my LT1 because the motor was out anyway. There is one place in all of the Ca tracks where my 18psi oil pressure warning light turns on for about half a second so I'm pretty happy with it. Quote Link to comment Share on other sites More sharing options...
Keith Posted February 22, 2007 Share Posted February 22, 2007 I'd think the easy of install probably affects a lot of people's decision as to one or another. I put a Canton in my LT1 because the motor was out anyway. That is where I am right now. I managed to get a Canton Pan with a car I recently bought and I will install it on the CMC car someday when the engine is out. I wouldn't take that on a project on it's own because it would be too much of a time committment.... Quote Link to comment Share on other sites More sharing options...
