Ken Baer Posted November 8, 2005 Share Posted November 8, 2005 Absolutely the best race car hauler built by Wildside in Franklin,TN Only used once, not even registered 34’ double deck race car trailer with hydraulic lift gate and full walk–on roof Smooth side exterior with no visible rivets plus diamond plate on front A-frame 26,000lb GVWR with 2 5/16” ball hitch, made to be pulled by Freightliner motorhome conversion Fluorescent and DC lights both upper and lower decks .040 aluminum lined and insulated walls and ceiling with stainless steel Stores 2 cars up and golf cart/pit cart down below Air compressor mounted in upper deck with air couplers throughout inside and curb side outside Nitrogen bottle cabinet and with nitrogen plumbed inside and outside Compressed air and 110VAC hose reels behind door available to curbside exterior AM/FM Stereo with amplifier Rubber disc flooring on lower level 60” side double door with fold out step and vinyl AC curtain Rear sliding doors on the lower level to close off when rear door is up or down Black Lista tool box 4 d-rings in lower level for a 15’ car at back Ladder and roof access on driver side at rear behind tire rack Winch upstairs with remote Two Arrow removable shelves mounted on exterior curb side and on lower level interior Arrow 14’x33’ pro-style free standing awning on curb side exterior with storage hangars Custom Technocraft cabinet package with lots of storage, work bench space, and parts washer. Lift ring centered on the outside of the rear door Panelite Millennium 1 red and amber marker lights 4 spotlights in rear door like dirt track guys use External speaker jacks on curb side including amplifier Exterior 110V receptacles at lower front, center and rear exterior curb side Rear docking lights on outside just behind rear wheels on each side enabled with reverse Two tire racks approximately 8’ long Onan 12KW Quiet Cat Diesel generator with 60 gallon fuel tank 2.5 Ton Bard AC on front with polished SS cabinet 220V outlet in front 3 flood lights on curb side 25’ shore power cord Electric over hydraulic STI triple disc brakes with air bag suspension Triple 8,000lb axles with 17.5” Alcoa aluminum wheels with 10-ply Michelin trailer tires Equalizer hydraulic lift at front Sunbrella cover Contact Paul Smith at 512 422 4677 or email at [email protected] Trailer is located in Austin, Texas Best trailer money can by at $99,500 Quote Link to comment Share on other sites More sharing options...
