power question
RichV
Right Matt, he must be running a SCAT crank, H beam rods and an internal balance crank. i bet it dont last him 1 race weekend.
And that would affect HP in what way?
Simple. Start with an unrestricted bone-stock 260HP engine
We're talking about a stock 5.0L here, right? Your definition of "bone-stock" must be a little different than mine.
4.6L PI motor.
Scott, I think spacers are OK in CMC, I'd have to check. The other thing would be to offset cam/crank timing, but I don't think that's legal.
The car looks and sounds good on the dyno, but sorry man. No EFI spacers allowed.
I'll let you check on the offset cam/crank timing. I don't recall seeing anything about it in the CMC rules, which translates to "not allowed".
(kind of like a rear shock tower brace)
I don't run a spacer Scott. The brace is a nice unit. My buddy makes them and wanted to get some install pics on a fox. Yes, I know it is not legal. Thanks for pointing that out BTW.
This is the thanks I get for helping you guys in March?? I think you still have my dustshield on your car. And, I still have a scar from your seat brace!! Punk.
I know you don't run a spacer. It was a suggestion for you as a way to build back some of your torque if it had been legal.
What seat brace?
Run the rear tower brace. Just don't ask what our car weighs.
I'll bring you two shiney new dust caps for you this month. Do you want me to paint them black match your wheels, or keep them silver to match your lug nuts?
Whats funny is the slowest/heaviest/most under powered hunk of poo poo is sitting 3rd in points.
Let Rich make 300hp and he will still be looking at the rear bumper of my car.
kyle
I'd like them white with a little #71 in red on each one.
I'll have another one on it. But, it may be a good thing for someone to have a spare or 2.
kyle
Keep it comin' tough guy. You better ride that '3rd in points' pony as far as you can. You just have MAD driving skills. And, I had a rod sitting in my oil pan.
kyle
Excuses excuses. If you where a real man you would have dropped that oil pan, yanked the broken rod and bearing, tossed it all back together and spanked the CMC field whole drinking coffee and eating a Danish.
Rich that car is gonna scream. I'm a dead man and Mike and Chris better watch out for ol #71.
kyle
The Cobra intake is probably hurting your torque numbers. My 5.0L makes 229/294 with E7s and a stock intake, stock 1.6 rockers and an HO cam. Ford revised the Cobra cam specifically to address lost low-end performance from the GT40 intake.
Hey Matt, you might be my new hero. Those are some empressive numbers for a 5.0. I'm a rookie in calif currently 2nd in points for cmc. I'm running a 95 mustang with the 5.0. I've rebuilt the engine with the cobra cam and the 1.7 rockers, stock intake. currently making 216/173. Any advice would be great. I need to catch Plum.
I'm very confident when I say CMC #6 will be the slowest car, just as long as we cross the checkered flag I'm happy.
I hope to return the favor to you Rich, Kyle and all my fellow NASA RM bro's should anything happen to your cars and I somehow have something or can offer something to get your cars back on the track.
Thanks Dave! I'm sure I'll be taking you up on something for sure!
Not sure if the Exploders are different. Is the cam/CR/pistons/crank the same as a Stang 5.0L? I know their intakes are a GT40 type, but I know those are not allowed as are the GT40P heads.
?? Dunno. I just need about 25 Ft/Lbs.
That may depend on who's driving.
Actually I'm just happy to have the car start and finish a race too.
Three words: Explorer short-block. 100 bucks at any junkyard.
No Explorer stuff allowed.
Explorer is not a Mustang
Maybe that could be rephrased as "No Explorer specific stuff allowed." As far as engine parts are concerned, it doesn't bother me a bit if the primary engine components come from a Mustang, Explorer, F150, Mercury, or Lincoln as long as the part in question has the same Ford part number as one that was also used as an original part on a Mustang.
E7 heads are E7 heads no matter if they were sourced from a F150, Mark VII, or a Mustang GT. They are all exactly identical and have the same part numbers. However, as the rules are currently written, even though an Explorer upper and lower intake manifold are essentially the same basic design as the upper and lower intake on a Mustang Cobra, there are some external cosmetic differences that also include a few vacuum port changes. These items do not have the same part numbers as those used on a Mustang, and therefore can not be used.
As with anything else, I see a balance to be struk here too. Rather than get into a long winded rant with pro/con examples, suffice to say that I do not 100% agree with either of the above quotations.
A short-block does not include heads or intake--that's a long-block. The Explorer short-block uses the same PN block, crank and rods as a Mustang. The pistons are hypereutectic flat-tops with four valve reliefs, just like in the 93-95 Mustangs. If you are running an FRPP replacement short-block purchased since about 1995, I GUARANTEE you already have an Explorer short-block, because that is what Ford used as service replacements and sold as crate engines. Besides, since the only difference is the pistons, it falls into the amorphous gray-area we already have on replacement pistons.
For the record, here's my combination that makes 231/294:
Stock 5.0L HO upper/lower intake
Stock 19 lb injectors
Stock HO MAF and throttle body
Stock E7 heads that I had rebuilt for 200 bucks about 6 years ago
New FRPP replacement short-block (production Explorer actually)
Stock 91 HO roller cam (heads and cam came from the same junkyard 91 Mustang)
Stock 1.6 stamped rocker arms
Stock factory air box w/K&N panel filter
Stock A9L computer w/Painless wiring harness
Stock HO tubular exhaust manifolds w/BBK X-pipe and open exhaust
