doug1548534725
.83 5th gear for T5
doug1548534725
Does anyone know where I can get the .83 5th gear set for a WC T5? I've been told only one manufacturer makes them, and I can't seem to dig anyone up that will sell one.
Share this post
Link to post
jeffburch
Tony Sarvis @ Astro Performance Warehouse.
jb
Share this post
Link to post
CMC#11
Call Astro Performance and talk to Tony, great guy. 561-999-5578
I just upgraded my Tremec 5th gear 2 weeks ago. Got the parts from them and everything worked great!!
Share this post
Link to post
doug1548534725
Wow, does $239 sound right just for the 5th gearset in .79? I know he's the only one making them, but wow.
Share this post
Link to post
jeffburch
.79?
A tad tall? Huh.
Yes.
Buy a spare
Share this post
Link to post
doug1548534725
He said that's the only size he makes for the trans I have, which doesn't sound right, but I'm not the expert. That's ok though, since with the extra power coming soon, I think I could go for a change to .79.
Maybe the replacement trans I picked up is special? The tag says it came out of a 92-92 V8 GM (1352-213).
Share this post
Link to post
Dave Schotz
When I looked to have my original '89 1LE Trans re-done... by D&D Performance.. they said the Ford T5 allowed for the .83... but the GM trans needed machining of some sort... so .78 or .79 was all they could do I believe for the factory GM box.
Or at least that's the line they sold me!
Dave
Share this post
Link to post
HMark
http://www.5speeds.com/t5/s80.html
$235 for a 0.83. That's what they go for. (for a Ford WC case)
There are some better gear sets out there, but they are 6 times that amount...
-Don
Share this post
Link to post
Tony G
Doug,
Why do you need a 5th gear,our T45's dont even have the possibility of a close 5th, so gear your car for max fourth gear and you will be fine (I know your thinking Willow Springs,but my times were actually faster gearing to 3.42-3.55's and keeping it in 4th for that track).
I never have any other issues running 3.73's anywhere else.
Tony Guaglione
Share this post
Link to post
jeffburch
The APW gear slip on the tail shaft really easy.
I had one from 5speeds.com that was a mutha to get on/off.
My tranny guy was much happier when I got him the APW set.
I agree with Tony, my next rearend will have 3.23's.
jb
Share this post
Link to post
Dave Schotz
At MO Jeff... did you have to go to 5th gear at all w/ the 3.42's?
Thanks,
Dave
Share this post
Link to post
cmc35
My SN95 (ex-Bondurant car) has a Tremec 3550 with a 3.55.
Most of the time, 4th is sufficient for the straights. But at our Rocky Mtn 'local' track (Pueblo) the front straight is 0.5 miles long, and I could really use a racing 5th gear.
Feedback from Tony/APW is that changing this tranny to a racing 5th is a little more involved than just the gear, but it doesn't sound too bad.
Any thoughts about alternatives?
thanks
chris
Share this post
Link to post
jeffburch
Yes Dave.
Wasn't in it long though.
jb
Share this post
Link to post
CMC#11
thanks
chris
Chris,
I also run the 3550 w/ 3.55's. I had been putting off the 5th gear install for the last 3 yrs. b/c you also have to change the main shaft.
TWS counter-clockwise is not that bad but going clockwise you are in 5th for a long time!! I gotta beat Proctor at this next event, and we are going clockwise.
I did the swap 2 weeks ago to the .82 gear and it cost (cough) $525. There are two ways of doing the swap:
1) get a 28 spline main shaft (which is a little more expensive) or
2) get a 31 spline main shaft (a little cheaper) but then you have to bore the tail housing and get a new d/shaft yolk. This ends up being more expensive in the long run. It does however change the ratio to a .85.
I stuck w/ the 28 spline shaft and everything went together perfectly.
If you have any other questions about it let me know.
Share this post
Link to post
cmc35
Michael,
Thanks, that sounds consistent with what I learned from Tony/APW.
-chris
Share this post
Link to post
