roadracerwhite Posted December 24, 2009 Posted December 24, 2009 We are putting an LT1 in our project car. Thanks to Glenn, Mitch, several schematics, several printouts and shop mainuals, I think we are well on our way. We worked on it tonight and think we have a good plan so far. It is in the car. Here is where we are at and a couple things to make note of; 1.Power steering pump and lines - have heard the LT1 pump will work with the steering box, but we are unsure about this. Need to do some more searching. 2.Fuel lines - Pure Choice Motorsports has adapter fittings to AN for both the LT1 fuel rail connections and the TPI fuel lines. 3.Wiring - Our engine is out of a 96 Camaro and we have the wiring harness and decided to use the stock harness instead of buying a stand alone. We are also working on splicing the lt1 harness into part of the TPI harness so we can use the stock gauges. You could definately spend your way out of having to sort through all these wires, but what fun is that? Bryan Quote
Keith Posted December 24, 2009 Posted December 24, 2009 Impressive and ambitious project. Please continue to provide updates! Quote
Shortcutsleeping1548534716 Posted December 24, 2009 Posted December 24, 2009 1. Yes it will work just fine. 2. Yup. Not sure that is the brand I used, but I did buy some fittings that made everything bolt right up. 3. You can do it! Take your time, label everything and when you alter stuff make schematics. It is slick to have all the factory stuff work right. Costas cars and such... Quote
nape1548534725 Posted December 24, 2009 Posted December 24, 2009 If you guys aren't in a big hurry, I probably still have the AN fittings from the body side fuel lines when I ran TPI. They're probably in the trailer in the fitting/braided line bin though. Quote
powerslide91 Posted December 24, 2009 Posted December 24, 2009 (edited) Intrested to hear what you learn. Also thanks to Mitch / Glenn / Mike, I just put an LT1 in my garage for future transplant. Did some reading on thirdgen.org and saw info about the power steering lines. I remember mention about using an Impala (??) line that worked good. Think it was in the FAQ so should be easy to find again. Edited December 25, 2009 by Guest Quote
mitchntx1548534714 Posted December 25, 2009 Posted December 25, 2009 shucks, fellers ... jus tryin' ta help ... Quote
cozog1548534733 Posted December 28, 2009 Posted December 28, 2009 I remember mention about using an Impala (??) line that worked good. Is the PS pump being replaced with a Turn One anyway? My understanding from LT1 racers is that the stock pump can't handle the high revs all day long, no matter how much cooling is used. Quote
Den341548534727 Posted December 30, 2009 Posted December 30, 2009 We ended up using the PS pump and bracket off of a 96 Caprice. The 4th gen Z28 has a rack and pinion steering but the B bodys have the old gear steering box like the third gens. So it simplified things just to grab the bracket and PS pump off the caprice. Then we went to the auto parts store and got a PS hose for a 96 Caprice. Slight modification of the hose bends and it looks like it is going to work well. The car is not running yet but the punch list is getting smaller and smaller. Bob Quote
Glenn Posted December 30, 2009 Posted December 30, 2009 be sure to document all this and we can add a supliment to the rulebook that will address things like this. Quote
roadracerwhite Posted January 5, 2010 Author Posted January 5, 2010 UPDATE; It ran for the first time on Saturday. Fired right up. Need to look into a couple issues. 1) Dies after about 15 seconds 2) tach doesn't work The o2 sensors aren't hooked up yet though (need to finish the exhaust) so we are a little unsure if that might be part of the issue with it dieing. Next up is finishing up the exhaust and looing everything up. Probably going to be a week or two though, since it is so cold here -1 on the way to work today. Bryan Quote
mitchntx1548534714 Posted January 5, 2010 Posted January 5, 2010 It was eye opening at how little wiring it took Quote
roadracerwhite Posted January 5, 2010 Author Posted January 5, 2010 Here are a couple reasources that we used. http://www.shbox.com/1/schematics_wiring.html Most of the way down on this page PCM pinouts and wiring http://www.shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts As well as an 88 shop manual and we had a c100 connector pinout for a third gen. (search on third gen.org) Quote
mitchntx1548534714 Posted January 5, 2010 Posted January 5, 2010 2) tach doesn't work I'm searching in my way-back machine, but doesn't a 4th gen (94+) use a different tach signal than the older models? I seem to recall that an aftermarket tach has to be set in 4 cylinder mode. Quote
Glenn Posted January 5, 2010 Posted January 5, 2010 only LS1 cars need the tach set for 4 cylinder mode. the LT1 cars are still on a V-8 signal set-up. its the 8 vs 1 ignition coil thing. Quote
FBody383 Posted January 6, 2010 Posted January 6, 2010 1) Dies after about 15 seconds Does the fuel pump stay on? When I de-wired my '94 last year I took the fuel pump relay directly to key-on. Sound VATS or security related. I subscribed to alldatadiy and printed a lot of the wiring diagrams. Good luck, sounds like you're close. Quote
AllZWay Posted January 6, 2010 Posted January 6, 2010 1) Dies after about 15 seconds Does the fuel pump stay on? When I de-wired my '94 last year I took the fuel pump relay directly to key-on. Sound VATS or security related. I subscribed to alldatadiy and printed a lot of the wiring diagrams. Good luck, sounds like you're close. I would look for this also. I had to purchase the VATS removal piece to get mine to work after I did the wiring on it. It acted very similiar to this. Quote
Den341548534727 Posted January 7, 2010 Posted January 7, 2010 Thanks for the advice guys. We will try looking into that and share our results when it gets a little warmer. It is not supposed to get above 20° for the next ten days. A high of 8° this weekend. ....Is it time for Hallet yet! Quote
mitchntx1548534714 Posted January 7, 2010 Posted January 7, 2010 VATS by-pass module ... http://mysite.verizon.net/vze7erz1/id1.html Been in my race car since 05. Quote
stevemichael Posted January 7, 2010 Posted January 7, 2010 Thanks for the advice guys. We will try looking into that and share our results when it gets a little warmer. It is not supposed to get above 20° for the next ten days. A high of 8° this weekend. ....Is it time for Hallet yet! Man, and I work in the garage when it's -15 out. We won't see 20 degrees again until late Feb up here. Quote
roadracerwhite Posted January 7, 2010 Author Posted January 7, 2010 VATS by-pass module ... http://mysite.verizon.net/vze7erz1/id1.html Been in my race car since 05. We took your advise and bought the Vats by pass module. Quote
CMC#11 Posted January 7, 2010 Posted January 7, 2010 Thanks for the advice guys. We will try looking into that and share our results when it gets a little warmer. It is not supposed to get above 20° for the next ten days. A high of 8° this weekend. ....Is it time for Hallet yet! Man, and I work in the garage when it's -15 out. We won't see 20 degrees again until late Feb up here. It is 20 degrees here today and everyone is freaking out. Quote
Adam Ginsberg Posted January 7, 2010 Posted January 7, 2010 It is 20 degrees here today and everyone is freaking out. 63^, and sunny. Slight breeze....might need to wear pants. Quote
Alien Posted March 23, 2010 Posted March 23, 2010 How's the car coming Bryan? Quick question on the oil pan (if you're using the Canton)... Are you able to use the 3rd gen (1pc rear) pan with the LT1 block? Is the 3rd oil pump and Canton pickup swappable to the LT1 block? Quote
Den341548534727 Posted March 24, 2010 Posted March 24, 2010 The car is basically sold. We are working out some details with the new owner and it will be running in the midwest. The answer is yes to both questions. LT1 block is basically the same as all one piece blocks, it just has a funky timing cover and casting in the front to accomodate the opti and water pump drive gear. Bob Quote
Alien Posted April 19, 2011 Posted April 19, 2011 I ended up going the LT1 route in my 3G. I need to post up my parts list soon. A thought occured to me today. A 4th gen with an LT1 can swap between CMC1 and CMC2 with a change in restrictor plate. A 3rd gen with an LT1 can't (per the rules). Doesn't seems right to me. Quote
