DrC Posted December 31, 2009 Share Posted December 31, 2009 Just like mattr, I am also in the middle of preparing my car for CMC next year. I was reading the article by Matt King in Muscle Mustang & Fast Fords where he said that some of the cars did not have window defoggers. My questions is do any of the CMC cars have window defoggers? The reason I am asking is I was about to take mine out to make room for the roll cage. Is that not a good idea? Quote Link to comment Share on other sites More sharing options...
DrC Posted December 31, 2009 Author Share Posted December 31, 2009 This is where I am today and plan to have it all cleaned out this weekend. Quote Link to comment Share on other sites More sharing options...
Den341548534727 Posted December 31, 2009 Share Posted December 31, 2009 Dan, Yes I have a defogger...It is a rag zip tied to the end of a stick! I use it to wipe the windshield when it gets to foggy to see. But The straight answer is no. Most do not have defoggers. Bob Quote Link to comment Share on other sites More sharing options...
stevemichael Posted December 31, 2009 Share Posted December 31, 2009 You need to get creative for defogging in the rain. The factory stuff is too heavy and the weight's in the wrong place. I believe the floor is a good source of heat on track. Quote Link to comment Share on other sites More sharing options...
KiMifan Posted December 31, 2009 Share Posted December 31, 2009 Just bolt a brake duct blower to the trans tunnel and run a piece of 4-inch ducting up under the dash below the windshield and run it off the same switch as the wiper motor. There's about 40 pounds of crap and complexity you can then get rid of under there! Quote Link to comment Share on other sites More sharing options...
stevemichael Posted December 31, 2009 Share Posted December 31, 2009 Just bolt a brake duct blower to the trans tunnel and run a piece of 4-inch ducting up under the dash below the windshield and run it off the same switch as the wiper motor. There's about 40 pounds of crap and complexity you can then get rid of under there! Spoon Feeding, much? Quote Link to comment Share on other sites More sharing options...
nasa-rm Posted December 31, 2009 Share Posted December 31, 2009 Since you are in OH, you NEED something. At the "constant rain national championships" I was very sorry I did not have our system still. I couldn't see anything and had to come in early during several sessions. Rag and stick works ok, but I would prefer somehting with an on/off switch. Quote Link to comment Share on other sites More sharing options...
Members Al F. Posted January 1, 2010 Members Share Posted January 1, 2010 I've had decent success with a brake duct hose zip tied to the a-pillar out in the air stream and running the other end to the base of the windshield. I can see how something more sophisticated would be nice to have. Quote Link to comment Share on other sites More sharing options...
DrC Posted February 17, 2010 Author Share Posted February 17, 2010 With this weather the progress is slow. Most of the drive train is out waiting on a new clutch. Also have a new flywheel on order. After looking it over found some teeth missing. All the in cab wiring was pulled out so we can put the Roll Cage in. Roll cage is setting on the floor at Dayton Performance(Shop) and hope to pick it up this week. And it looks like we are getting more show this weekend. List of what has to be done by April 1st Get drive train back in Install Roll Cage Re-wire everything that is not under the hood. I will have more pictures later. Quote Link to comment Share on other sites More sharing options...
GT4Point6 Posted February 18, 2010 Share Posted February 18, 2010 Rain-X for the interior part of the winshield works wonders in damp and rain conditions! Gut the blowers, not needed, neither are the wipers, Rain-X for the exterior! Quote Link to comment Share on other sites More sharing options...
Sidney Posted February 18, 2010 Share Posted February 18, 2010 ...not needed, neither are the wipers, Rain-X for the exterior! Dan, DO NOT LISTEN TO THIS ADVISE. You'll need the wipers if you intend to race in the Midwest/Great Lakes area...which you are. I've been racing here for 10 years and not having wipers will have you parked. Don't believe me...next time you're on the interstate pull up behind a semi and shut your wipers off. That's what it looks like in the middle of a pack when the green drops. It's completely different than driving in the rain with RainX running 70 mph out in the open. It's the spray off the pack that does not run off the window and is especially bad when speeds drop coming up to a corner. Now for the smartass that says if you're fast you'll be out front and won't be in the spray. Sorry but no matter how fast you are this is a CMC site and CMC cars start behind AIX & AI. So if you're as fast as I am in the rain you'll eventually pass most of them but if Griswald's got his cheater Hoosier Dirt Trackers on and Rusty has the Traction Control switch up...then you'll likely be following some serious spray! Keep the wipers. Sidney Franklin CMC #64 Quote Link to comment Share on other sites More sharing options...
nasa-rm Posted February 18, 2010 Share Posted February 18, 2010 and not having wipers will have you parked. Yes. I spent a good amount of time at the 2008 Championships at MO coming off track early and parking. I couldn't see anything and it was downright dangerous. Rain-X, defogger on the inside, etc - nothing worked except to park and wait for dry weather. Quote Link to comment Share on other sites More sharing options...
mitchntx1548534714 Posted February 18, 2010 Share Posted February 18, 2010 I think Kevin may be describing Southern California desert rain ... Quote Link to comment Share on other sites More sharing options...
KiMifan Posted February 18, 2010 Share Posted February 18, 2010 DrC lives in Ohio. That means he'll be racing at Mid Ohio. That means he WILL race in the rain. If you don't have wipers and a blower or defroster in your car, god help you. Quote Link to comment Share on other sites More sharing options...
DrC Posted February 19, 2010 Author Share Posted February 19, 2010 Yes I plan to spend most of my time at Mid Ohio. I may have to rethink this. I had planned to keep the wipers but remove the defogger. I was looking to hook up a fan that would use the vent to blow fresh air on to the window but not heated. We have a place here in Dayton call Mendelsons Liquidation Outlet that has a lot of old GM electrical items. Dayton was a big GM town before everything closed. That is where I found a fan and my switches for my control panel. New update: Picked up my parts for my roll cage, and other items to install T5. This weekend To Do List. Replace Rear main seal Install new: *Pilot bearing and flywheel, *Spec Stage 1 Clutch * upgraded T5 with .82 fifth gear. Thanks Bob Denton for the words of encouragement. It is cold here and more snow on the way for this weekend. I have spent more time behind my snow blower then working on the car. Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 19, 2010 Share Posted February 19, 2010 the only place i ever wished i had wipers was at Mid Ohio. the only place i ever wished i had a defroster was at Mid Ohio. looking out the side window for the braking marker at the end of the back straight (Turn 7?) thinking your gonna brake at the 4 or 3 cone and you see the 1 cone fly by is not fun! Quote Link to comment Share on other sites More sharing options...
KiMifan Posted February 19, 2010 Share Posted February 19, 2010 You don't need to keep the whole factory heater/defroster unit. I would save a couple of the underdash vents and rig up a brake duct blower to the trans tunnel. That works pretty well. Quote Link to comment Share on other sites More sharing options...
JermBua Posted February 19, 2010 Share Posted February 19, 2010 New update: Picked up my parts for my roll cage, and other items to install T5. This weekend To Do List. Replace Rear main seal Install new: *Pilot bearing and flywheel, *Spec Stage 1 Clutch * upgraded T5 with .82 fifth gear. I would check the pilot bearing and just lube it with some good grease. Those can be a real bixxx to get out. I have not seen one fail yet. Work smart not hard. Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted February 20, 2010 Share Posted February 20, 2010 Get OTC # 7318 for replacing the pilot bearing and save yourself a ton of hassle. http://www.sjdiscounttools.com/otc7318.html The other methods might or might not work, but this tool makes it effortless. Mark Quote Link to comment Share on other sites More sharing options...
JermBua Posted February 20, 2010 Share Posted February 20, 2010 Get OTC # 7318 for replacing the pilot bearing and save yourself a ton of hassle. OTC Makes a good tool. So does Snap-On. Do not by a cheap knock off. It wont save you money in the long run. Quote Link to comment Share on other sites More sharing options...
sacabuche Posted February 20, 2010 Share Posted February 20, 2010 Why not use the wet newspaper method, only takes a few seconds to pull out that bearing. Makes it very easy to do when under a car on jackstands. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted February 20, 2010 Share Posted February 20, 2010 If you're going to reference the "wet newspaper" method, you better describe it too, because I have no idea what you're talking about. Quote Link to comment Share on other sites More sharing options...
KiMifan Posted February 20, 2010 Share Posted February 20, 2010 Fill the recess in the crankshaft with grease and use a snug fitting socket and extension to hammer the old bushing out. Works like a charm. "wet newspaper" is probably a variation on that theme, but I agree that there's probably no reason to even both with replacing the bearing if it's not obviously worn. Quote Link to comment Share on other sites More sharing options...
sacabuche Posted February 20, 2010 Share Posted February 20, 2010 Fill the recess in the crankshaft with grease and use a snug fitting socket and extension to hammer the old bushing out. Works like a charm. "wet newspaper" is probably a variation on that theme, but I agree that there's probably no reason to even both with replacing the bearing if it's not obviously worn. That is exactly how its done, much neater than using grease, too. Its great when you don't have the tools on the spot. Quote Link to comment Share on other sites More sharing options...
liebbe1548534713 Posted February 21, 2010 Share Posted February 21, 2010 Wipers Rule!!! And thanks for the brake duct blower defroster idea. Quote Link to comment Share on other sites More sharing options...
