4th gen fans
Posted (edited)
Are people using somethingbesides the stock fans/shroud on these cars? I was looking at a single 2350 cfm fan wired to the master switch to cut some pounds off the nose of the car. Does anyone have any experience with nonstock fans?
Steve
I'll bet if you have a good radiator and properly duct the air through it, you won't even need a fan.
  • Members
Plenty of 4th gens are out there without fans. Some will borderline overheat when coming off track and going through tech. I put mine back for that reason. Its a generic electric pull.
Do you happen to know the diameter or cfm? That's the only thing I am worried about. I have seen people push their cars to tech due to long lines coming off the track in congested pit areas (BFR).
  • 1 month later...
I still have the stock wire harness in the car and just pulled out the dual fan set up yesterday. Would there be anything wrong with re-terminating one of the stock fan plugs and plugging it into my new, universal fan? Does the thermostat for the stock fans use a signal from one of the temp senders?
Steve
  • 4 weeks later...
Steve
The answer is yes, you can splice into factory wiring for the fan to tunn on and off based on the temp signal used by the PCM. It is interesting that the factory fan set up weighs 14 lbs. Dumping that set up sure helps get weight off the front end of the car.
We wired our 3rd gens fans onto separate switches. Last season they were used more for keeping the car cool on grid than during the races. Wiring them is a snap.
