Pat Stone1548534713 Posted January 23, 2010 Posted January 23, 2010 (edited) going to carb on ford 302. can we use hei dist like gm old style? other wise i would have to put a kit in older dist . hei set up is very simple, and cost effective. one wire. ps Edited February 3, 2010 by Guest Quote
KiMifan Posted January 23, 2010 Posted January 23, 2010 It certainly isn't in the rules now. You would have to use a Duraspark ignition setup with the compatible distributor. If you're running a roller cam, the application is from an 85 5.0L five-speed, which will have the correct steel distributor gear to match the cam. Quote
ColtSmoke Posted February 25, 2011 Posted February 25, 2011 It certainly isn't in the rules now. You would have to use a Duraspark ignition setup with the compatible distributor. If you're running a roller cam, the application is from an 85 5.0L five-speed, which will have the correct steel distributor gear to match the cam. What type of ignition coil can be used when doing the carb conversion on a ford? TFI or Canister? Quote
Adam Ginsberg Posted February 25, 2011 Posted February 25, 2011 My 85 Fox3 carbed hooptie is using a stock 85 coil that looks like the 86+ EFI coils. Walk into AutoZone/Kragen/etc and ask for a stock 85 coil to go with the 85 Duraspark distributor, and the 85 Duraspark box. Simple, effective, and very inexpensive. Quote
ColtSmoke Posted February 25, 2011 Posted February 25, 2011 My 85 Fox3 carbed hooptie is using a stock 85 coil that looks like the 86+ EFI coils. Walk into AutoZone/Kragen/etc and ask for a stock 85 coil to go with the 85 Duraspark distributor, and the 85 Duraspark box. Simple, effective, and very inexpensive. Thanks for you help. Quote
