TxCMC22 Posted February 15, 2011 Author Share Posted February 15, 2011 hey CF03GT thanks for posting. I have a couple of questions if you don't mind. What color are your injectors? What are the following part numbers? MAF ????-12B579-??** Throttle Body? Computer? Fuel Rail pressure sensor? Fuel pump being used? are you using the plastic intake? or another intake from ford? Just trying to gather some data on cars making the numbers, maybe there is something there... Quote Link to comment Share on other sites More sharing options...
ShadowBolt Posted February 15, 2011 Share Posted February 15, 2011 hey CF03GT thanks for posting. I have a couple of questions if you don't mind. What color are your injectors? What are the following part numbers? MAF ????-12B579-??** Throttle Body? Computer? Fuel Rail pressure sensor? Fuel pump being used? are you using the plastic intake? or another intake from ford? Just trying to gather some data on cars making the numbers, maybe there is something there... And no F'ing long tubes! JJ Quote Link to comment Share on other sites More sharing options...
TxCMC22 Posted February 15, 2011 Author Share Posted February 15, 2011 hey CF03GT thanks for posting. I have a couple of questions if you don't mind. What color are your injectors? What are the following part numbers? MAF ????-12B579-??** Throttle Body? Computer? Fuel Rail pressure sensor? Fuel pump being used? are you using the plastic intake? or another intake from ford? Just trying to gather some data on cars making the numbers, maybe there is something there... And no F'ing long tubes! JJ I still have my stock manifolds if you want them Jerry! I was told the same thing!!!! Quote Link to comment Share on other sites More sharing options...
CF03GT Posted February 15, 2011 Share Posted February 15, 2011 Everything is stock/as delivered from Ford on the car, so.. What color are your injectors? -Pink What are the following part numbers? MAF ????-12B579-??** -YC2F-12B579-BA AFH80-06D 3B04 Throttle Body? - Stock (cant make out the numbers on the TB sensor) Computer? -XSH2 3R3A-12A650-DC MPC14G Fuel Rail pressure sensor? - 3R3E 9F972 AA Fuel pump being used? -Stock are you using the plastic intake? or another intake from ford? - Stock plastic -Chris #14 CMC2 Quote Link to comment Share on other sites More sharing options...
ShadowBolt Posted February 15, 2011 Share Posted February 15, 2011 hey CF03GT thanks for posting. I have a couple of questions if you don't mind. What color are your injectors? What are the following part numbers? MAF ????-12B579-??** Throttle Body? Computer? Fuel Rail pressure sensor? Fuel pump being used? are you using the plastic intake? or another intake from ford? Just trying to gather some data on cars making the numbers, maybe there is something there... And no F'ing long tubes! JJ I still have my stock manifolds if you want them Jerry! I was told the same thing!!!! If I could make the numbers Chris is making without them I would take you up on the offer. Even a starter change with the long tubes and the Canton oil pan is a bitch. JJ Quote Link to comment Share on other sites More sharing options...
TxCMC22 Posted February 15, 2011 Author Share Posted February 15, 2011 they are used, I don't want them... I was going to scrap them... Chris thanks for the info... I will dig a bit further Quote Link to comment Share on other sites More sharing options...
