aheld131548534742 Posted December 29, 2011 Share Posted December 29, 2011 I would like to get some of your input on brake set-ups for 3rd gens. What set-ups do you have? I was thinking about a 4TH GEN set up in the front and the same 4TH GEN front rotor on the rear with a single piston caliper. So basically 12 in rotors all the way around dual piston front single piston rear. Will this be a decent set-up or not??? trying to get a decent brake set-up cheap to start racing Quote Link to comment Share on other sites More sharing options...
roadracerwhite Posted December 29, 2011 Share Posted December 29, 2011 Most people use the ls style brake caliper (98-02 firebird and camaro) on the front and the stock rear disc setup. You don't want to run those big rotors on the rear, there is no need for it, just more weight to turn. That much brake in the rear is just going to cause lockup and give you problems. Bryan Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted December 29, 2011 Author Share Posted December 29, 2011 ok thanks yea the 98-02 ls1 brakes up front was what i was thinking. but for the rear all i have is drum rears and i was thinking about putting a ford 9" in and it also has drums so whats the best rear disc brakes to run? Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 29, 2011 Share Posted December 29, 2011 The 9" is overkill as well. Convert the stock 10 bolt over to OEM disc's from a 3rd gen or a 4th gen (93-97). Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted December 29, 2011 Author Share Posted December 29, 2011 ok thanks for the advice i drag race too and i overkill alot of my builds but i guess your right the 10bolt should be ok with the horsepower restrictions i blew 4 10bolts apart in my camaro drag car then i put a ford 9 with 35 spline axles been good for the past 5 years but i got around 500HP in that Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 29, 2011 Share Posted December 29, 2011 I'm on the same 10 bolt I started w/ in 2005. Not enough power or grip to hurt one. Quote Link to comment Share on other sites More sharing options...
roadracerwhite Posted December 29, 2011 Share Posted December 29, 2011 The weak part for a ten bolt road racing is the gears, but it depends on which gear you run. I have had good luck with 3.90's but 3.73's and 4.10's seem to wear out after about 13 races. As far as rear brakes go, I would stick with the stock pbr style calipers which came on 89 -97 cars you will need brackets from a third gen rear though. And there is enough flange on the rear end you have to convert it from drum to disc. Quote Link to comment Share on other sites More sharing options...
raybob92891548534723 Posted December 29, 2011 Share Posted December 29, 2011 Let me know if you need some 98& up front caliper brackets. I usually have those layin around and some caliper cores. Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted December 29, 2011 Author Share Posted December 29, 2011 ok thank guys what for brake pads do you guys run? Quote Link to comment Share on other sites More sharing options...
ls168camaro Posted December 29, 2011 Share Posted December 29, 2011 Carbotech XP 10's on front. Azone's on the rear. Quote Link to comment Share on other sites More sharing options...
FBody383 Posted December 29, 2011 Share Posted December 29, 2011 Carboech XP 10's on front. Azone's on the rear.+1. or O'Reilly or whatever on the rear Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 30, 2011 Share Posted December 30, 2011 XP8's in the rear. Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted December 30, 2011 Author Share Posted December 30, 2011 what do you guys think about this kit for rear brakes http://www.speedwaymotors.com/GM-75-Inch-10-Bolt-Bolt-On-Rear-Brake-Kits,14021.html Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 30, 2011 Share Posted December 30, 2011 You could buy a complete rear axle w/ the gears you need and the brakes you want for less than that. Then sell your current one for whatever you can. Quote Link to comment Share on other sites More sharing options...
roadracerwhite Posted December 30, 2011 Share Posted December 30, 2011 what do you guys think about this kit for rear brakes http://www.speedwaymotors.com/GM-75-Inch-10-Bolt-Bolt-On-Rear-Brake-Kits,14021.html I don't know 300 bucks for everything new might be ok. The third gen brackets aren't the easiest to find and the 4th gen brackets don't fit on third gens. So you might look for something like these instead; http://www.ebay.com/itm/WS6-rear-disc-brake-calipers-and-brackets-Firebird-Camaro-Formula-350-1989-/250962599722?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3a6e895f2a#ht_500wt_1413 The kit you posted a link to is more like the earlier style rear discs on third gens. They should work fine. Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted December 31, 2011 Author Share Posted December 31, 2011 Thanks for that link im watching them rate now just thinking some things over before i buy something i mite not use Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted December 31, 2011 Author Share Posted December 31, 2011 does anyone have a set of 1LE spindles ??? Quote Link to comment Share on other sites More sharing options...
roadracerwhite Posted January 1, 2012 Share Posted January 1, 2012 does anyone have a set of 1LE spindles ??? Most people just make their own, using the non-1le spindles. Just need a sawzaw, grinder, drill, and a tap. Something else to think about when tapping the spindle you might use a English thread instead of metric. Might make it easier down the road to get grade 8 bolts for. Bryan Quote Link to comment Share on other sites More sharing options...
nwv02 Posted January 1, 2012 Share Posted January 1, 2012 I modified a few sets of spindles and to share my experience, I would suggest you look for a set of late 3rd gen spindles to modify, in the 1990-1992 range. The amount of material around the hole that you are drilling and tapping is greater in those year spindles. My post is here: http://www.thirdgen.org/techboard/posts/brake-board/593482-modified-z28-spindles-1le/4726877-post9.html Note: these holes were drilled to fit and accomodate the hardware for standard OEM GM 3rd gen 1LE brackets. Here is a good info page for the 1LE upgrade. http://www.ws6transam.org/1LEbrake.html Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted January 2, 2012 Author Share Posted January 2, 2012 thanks for the info guys I didn't realize that the spindles were that close to each other i thought they were totally different Quote Link to comment Share on other sites More sharing options...
APatelIroc Posted January 4, 2012 Share Posted January 4, 2012 what about those that have the C5 front setup? Is it that much better than the ls1 setup? is it worth the cost? Have you looked at bigbrakeupgrade or flynbye ? http://www.bigbrakeupgrade.com/ http://flynbye.com/ i was looking at the C5 front setup personally for when i get started on my build this spring. For the rear i also am sticking to the stock 93-97 disc setup. Quote Link to comment Share on other sites More sharing options...
roadracerwhite Posted January 4, 2012 Share Posted January 4, 2012 what about those that have the C5 front setup? Is it that much better than the ls1 setup? is it worth the cost? Have you looked at bigbrakeupgrade or flynbye ? http://www.bigbrakeupgrade.com/ http://flynbye.com/ i was looking at the C5 front setup personally for when i get started on my build this spring. For the rear i also am sticking to the stock 93-97 disc setup. Not sure if it is worth it, as far as I can tell; the only difference between the two is on uses corvette rotors (13in) instead of 12 in rotors. I run 16in wheels (GTA) so I am pretty much stuck with 12in rotors, Some of the 16 in camaro wheels will c lear 13in brakes though. Quote Link to comment Share on other sites More sharing options...
Members Al F. Posted January 5, 2012 Members Share Posted January 5, 2012 C5 calipers and LS1 calipers are not the same. The C5 caliper is stiffer across the bridge and therefore more resistant to the clamshelling that some LS1 brake owners have experienced. They require a bit of grinding to clear most 16" wheels when mounted on 12" rotors but they will work. Quote Link to comment Share on other sites More sharing options...
APatelIroc Posted January 5, 2012 Share Posted January 5, 2012 im planning on running 17" wheels so shouldnt be an issue. Was curious if anyone else ran this setup or not and was alos a suggestion if the money allowed for it. Quote Link to comment Share on other sites More sharing options...
aheld131548534742 Posted January 6, 2012 Author Share Posted January 6, 2012 WELL I GOT MY DISC BRAKE SET UP FOR THE REAR TODAY IN THE MAIL BYE BYE DRUMS LOL NOW STILL NOT SURE ON THE FRONT BRAKES 1LE, HOME MADE 1LE WITH C4 CALIPERS, LS1 OR C5 ??? TIME WILL TELL Quote Link to comment Share on other sites More sharing options...
